It is currently Wed Jun 24, 2026 3:26 pm
 Post subject: Vacuum pressure
PostPosted: Tue Jul 08, 2008 2:17 pm
How much vacuum should I see at idle?
I have right at 7 inches and at choke it is about 20.
Thanks,
Superman
1981 D150
"The Khaki Machine"
PostPosted: Tue Jul 08, 2008 2:52 pm
Depends upon the rpm, in gear verses out of gear, one barrel or two.
I run about 16.5" in gear at 550 rpm on a 85 degree day.
18" out of gear with a Holley 1920.
PostPosted: Tue Jul 08, 2008 5:32 pm
Car Model: 63 Dart 81 D150
With a carter 2bbl on a super six manifold and a stock cam I see 15"~16" at an 650 rpm idle in neutral. I have my dash gauge hooked in to a T fitting in the pcv hose. My second dash gauge is hooked in to a T fitting in to the vacuum advance at the distributor, I see as much as 20" inches at cruise.
TopHat
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
