It is currently Mon Dec 29, 2025 4:25 am
PostPosted: Sat Jul 12, 2008 9:52 pm
I have been driveing the Guzzi twin motor car the past two weeks, tweeking tuneing, MY guestimate,2,500 lb 62 valiant,low 15 second car,185 true rear wheel hp,This is MY GUESSTIMATE,going to dyno next week ,scale on monday,will post pics next fri before I tear back down for paint,to me ,it is brutally fast,will post the actuall numbers,mark
PostPosted: Mon Jul 14, 2008 5:33 am
Sounds like progress, Mark. Interested to see dyno numbers.
PostPosted: Mon Jul 14, 2008 9:51 am
So... are the "tuners" in the shop on the next block going to let you use their chassis dyno?
Try some different total timing settings. 26, 28, 30, 32 degrees... see what it likes. ( have the fuel mix you plan to run)
Limit RPMs to 5500 or so, don't blow it up with over reving. (tuners will want to rev it high.)
 Post subject: Guzzi twin pics thread
PostPosted: Fri Jul 18, 2008 7:21 pm
SORRY, I am VERY computer illeterate...
I posted pics of my car in the guzzi twin "weight"-chop top update,took forever for me just to get them on this forum.please someone move them to where they should be and be seen,last time I posted pics I got Several very helpfull tips,any comments wanted and welcomed,positive or negative,would not have been able to build this car without this forum,THANKS,Mark
PostPosted: Fri Jul 18, 2008 7:45 pm
Here is a link to the thread with the photos:
http://www.slantsix.org/forum/viewtopic.php?t=30055
PostPosted: Fri Jul 18, 2008 8:48 pm
If You have that Much RWHP With Your car Being as light as it is you should be deep into the 14's or high 13's..
Based off my cars Times, Weight, and RWHP.
My best is a 14:72 With 184.5 RWHP weighing 3380#..
It will be interesting to see what the car runs!
Good Luck,
PostPosted: Fri Jul 18, 2008 9:24 pm
IF, is the big question,will know more after I get it out of the paint shop and put it on the dyno.My goal is just break a 100,and be just under 14 sec,I think it is possible with this car,no juice Mark
PostPosted: Sat Jul 19, 2008 10:40 am
If you make the power You Are Guessing it will make then I say it will do it!!
What rear gear are you running??
PostPosted: Sat Jul 19, 2008 1:15 pm
391 in it now,will be putting 456 in it for the 1/8th.mark
