It is currently Tue Dec 30, 2025 4:38 am
 Post subject: 225 Knocking
PostPosted: Tue Jul 15, 2008 9:24 pm
84k origanal on 225 automatic in a 73 dart sport. All rockers adj correctly .10 and .20. Taken pan down removed 4 and 5 rod caps, normal breakdown. Noise still rear of engine inside block. Rev up and as rpm lowers nockinf is louder then normal tick, it always the lowdest after reving.
PostPosted: Tue Jul 15, 2008 10:04 pm
6 Pack Dart
you might check the convertor bolts
PostPosted: Wed Jul 16, 2008 8:41 am
Worn-piston pin or a collapsed piston?
PostPosted: Thu Jul 17, 2008 3:35 pm
Did that vehicle use a flex plate? Old Fords knock like crazy with a cracked flex plate, and it's sometimes difficult to tell the difference between that and a rod knock.
PostPosted: Thu Jul 17, 2008 4:13 pm
I 2nd that
