It is currently Sun Dec 28, 2025 4:33 pm
PostPosted: Sun Jul 20, 2008 10:20 am
Well I got my car running and am driving it and tuning.My question is what are you guys with a healty (modified) engine runnig for temps on the street?My car runs 200 on the highway and 205-210 in heavy traiific.I was running 50/50 water and coolant.So yesterday I flushed it a out and put in _40,distilled water and 2 qts. of pink anti-freeze.The race shop up the road said I should expect about a 10 degree cooler engine.Well it now runs 5 degrees hotter.I have a 185 thermostat,Mopar Varroicios clutch fan and a double pass alu. radiator and a 19-21lbs cap.Timigs good and just rechecked valves.Granted it's 105 overbore and a lot of headwork with 10.6-1 comppresion.Does the 200-205 sound comparable with some of yours?The motor man said it should be fine just don't want to see 220-230.The radiator hose are equal once warmed up (it only tkaes about 1 mile to rear temp.Any thoughts or suggestions? :?: :?:
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
 Post subject: Augh!
PostPosted: Sun Jul 20, 2008 10:23 am
That's is very good temps with green stuff 50/50.
Stop listening to the speed shops. Listen to here.
Cheers, Wizard
