It is currently Sun Nov 29, 2026 12:56 pm
PostPosted: Tue Jul 22, 2008 11:48 am
I recently purchased a '65 valiant100 170c.u. 3 on tree standard that has been parked about 10 yrs. I'm gonna soon check fluid levels in standard transmission and rear end and wonder the proper fluids in case they are low.I'll be replacing the fluid very soon but for now want to make sure all are full. thnx for advice
jimmy
1965 Plymouth Valiant100 170c.u. 3 on the tree with A/C
 Post subject: gear oil
PostPosted: Tue Jul 22, 2008 7:44 pm
Car Model: 1974 W100; 72 Dart
75W90
80W90
85W140.
I listed those in order of how hard they are to pump into your tranny/rear. I usually use 80W90 in everything from my 833OD to my rear ends to the gear case on my harley to the lower unit on my OLD boat. It seems to get the job done. For gear oil I have steered away from synthetics after reading somewhere that they don't climb the gears the way the dino stuff does.
I would get a gallon and a pump top cap to make things go A LOT easier no matter which weight you go with. Just ask at any auto parts store for the gear oil and get the most affordable gallon. To make the oil flow a bit easier, you can set the gallon out in the sun while the fluids drain from the tranny and rear. It'll ease the flow.
Hope that helps a bit.
sb
