It is currently Wed May 27, 2026 7:26 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Wed Dec 19, 2001 1:17 pm
I noticed a clutch linkage problem with my
64 Dart 4spd car about two weeks ago. my pedal was hanging on its way back up. the clutch worked fine, engaged and disengaged with no problems, I just had use my toe and pull the pedal back up.... It finally gave up the ghost last weekend went the pedal went to the floor and didn't affect the clutch at all.
well I got the bottom of the problem, my z-bar cracked along the tube and the arm on the bellhousing side bent back.
so if anyone has a 63-66 A-body z-bar for a slant six that they can spare,, email me at <A HREF="mailto:doug@autohobbydigest.com">doug@autohobbydigest.com</A>. I'm open to trading (christmas budget has purse strings way too tight) I have a 67-76 A-body slant six z-bar I'll trade, as well as various slant six parts, like a set of 170 push rods... if you aren't interested in trading, let me know what you want for the z-bar.
Merry Christmas!
picture of car in question
 Post subject: Have it welded?
PostPosted: Wed Dec 19, 2001 4:55 pm
I searched for a while just to find a z-bar for my '65. I'm still looking for the 3 bolt plate that attaches to the fender for the pivit bolt (Hint, hint). It should weld up as good as new. Faster and shouldn't cost much. Just my 2c...
Mike
MAndreas@aol.com
PostPosted: Wed Dec 19, 2001 5:18 pm
: I noticed a clutch linkage problem with my
: 64 Dart 4spd car about two weeks ago. my pedal
: was hanging on its way back up. the clutch
: worked fine, engaged and disengaged with no
: problems, I just had use my toe and pull the
: pedal back up.... It finally gave up the
: ghost last weekend went the pedal went to
: the floor and didn't affect the clutch at
: all.
: well I got the bottom of the problem, my z-bar
: cracked along the tube and the arm on the
: bellhousing side bent back.
: so if anyone has a 63-66 A-body z-bar for a
: slant six that they can spare,, email me at
: <A HREF="mailto:doug@autohobbydigest.com">doug@autohobbydigest.com</A> . I'm open to
: trading (christmas budget has purse strings
: way too tight) I have a 67-76 A-body slant
: six z-bar I'll trade, as well as various
: slant six parts, like a set of 170 push
: rods... if you aren't interested in trading,
: let me know what you want for the z-bar.
: Merry Christmas!
Doug, I'll go dig around in the garage. I have the one out of my '66 I think. (I sent one to someone else, but I think it was the one out of my '71.)
slantzilla@excite.com
PostPosted: Wed Dec 19, 2001 9:50 pm
We make our own-with roller bearings and all. Just think about it and start to it.
Will
: all.
: Merry Christmas!
slantsix@netzero.net
 Post subject: 3 bolt plate
PostPosted: Thu Dec 20, 2001 7:37 am
: I searched for a while just to find a z-bar for
: my '65. I'm still looking for the 3 bolt
: plate that attaches to the fender for the
: pivit bolt (Hint, hint). It should weld up
: as good as new. Faster and shouldn't cost
: much. Just my 2c...
: Mike
Don't know about the Z-bar, but the 3-bolt plate should still be floating around the garage, want me to look for it tonight?
matt-
mhaskell@reliant.com
 Post subject: Re: 3 bolt plate!!!!!!
PostPosted: Thu Dec 20, 2001 8:40 am
: Don't know about the Z-bar, but the 3-bolt
: plate should still be floating around the
: garage, want me to look for it tonight?
: matt-
ABSOULTELY!!! I've missed a couple at my local Pick-A-Part. That and a hump and I think I'm done.
Mike
MAndreas@aol.com
