| clutch linkage problem, need a z-bar https://slantsix.org/forum/viewtopic.php?t=3018 |
| Author: | Doug Ahern [ Wed Dec 19, 2001 1:17 pm ] |
| Post subject: | clutch linkage problem, need a z-bar |
I noticed a clutch linkage problem with my 64 Dart 4spd car about two weeks ago. my pedal was hanging on its way back up. the clutch worked fine, engaged and disengaged with no problems, I just had use my toe and pull the pedal back up.... It finally gave up the ghost last weekend went the pedal went to the floor and didn't affect the clutch at all. well I got the bottom of the problem, my z-bar cracked along the tube and the arm on the bellhousing side bent back. so if anyone has a 63-66 A-body z-bar for a slant six that they can spare,, email me at <A HREF="mailto:doug@autohobbydigest.com">doug@autohobbydigest.com</A>. I'm open to trading (christmas budget has purse strings way too tight) I have a 67-76 A-body slant six z-bar I'll trade, as well as various slant six parts, like a set of 170 push rods... if you aren't interested in trading, let me know what you want for the z-bar. Merry Christmas! picture of car in question doug@autohobbydigest.com |
| Author: | Mike Andreas [ Wed Dec 19, 2001 4:55 pm ] |
| Post subject: | Have it welded? |
I searched for a while just to find a z-bar for my '65. I'm still looking for the 3 bolt plate that attaches to the fender for the pivit bolt (Hint, hint). It should weld up as good as new. Faster and shouldn't cost much. Just my 2c... Mike MAndreas@aol.com |
| Author: | dschumers [ Wed Dec 19, 2001 5:18 pm ] |
| Post subject: | Re: clutch linkage problem, need a z-bar |
: I noticed a clutch linkage problem with my : : 64 Dart 4spd car about two weeks ago. my pedal : was hanging on its way back up. the clutch : worked fine, engaged and disengaged with no : problems, I just had use my toe and pull the : pedal back up.... It finally gave up the : ghost last weekend went the pedal went to : the floor and didn't affect the clutch at : all. : : well I got the bottom of the problem, my z-bar : cracked along the tube and the arm on the : bellhousing side bent back. : : so if anyone has a 63-66 A-body z-bar for a : slant six that they can spare,, email me at : <A HREF="mailto:doug@autohobbydigest.com">doug@autohobbydigest.com</A> . I'm open to : trading (christmas budget has purse strings : way too tight) I have a 67-76 A-body slant : six z-bar I'll trade, as well as various : slant six parts, like a set of 170 push : rods... if you aren't interested in trading, : let me know what you want for the z-bar. : : Merry Christmas! Doug, I'll go dig around in the garage. I have the one out of my '66 I think. (I sent one to someone else, but I think it was the one out of my '71.) slantzilla@excite.com |
| Author: | Will [ Wed Dec 19, 2001 9:50 pm ] |
We make our own-with roller bearings and all. Just think about it and start to it. Will Quote:
: I noticed a clutch linkage problem with my : : 64 Dart 4spd car about two weeks ago. my pedal : was hanging on its way back up. the clutch : worked fine, engaged and disengaged with no : problems, I just had use my toe and pull the : pedal back up.... It finally gave up the : ghost last weekend went the pedal went to : the floor and didn't affect the clutch at : all. : : well I got the bottom of the problem, my z-bar : cracked along the tube and the arm on the : bellhousing side bent back. : : so if anyone has a 63-66 A-body z-bar for a : slant six that they can spare,, email me at : <A HREF="mailto:doug@autohobbydigest.com">doug@autohobbydigest.com</A> . I'm open to : trading (christmas budget has purse strings : way too tight) I have a 67-76 A-body slant : six z-bar I'll trade, as well as various : slant six parts, like a set of 170 push : rods... if you aren't interested in trading, : let me know what you want for the z-bar. : : Merry Christmas! slantsix@netzero.net |
| Author: | Matt [ Thu Dec 20, 2001 7:37 am ] |
| Post subject: | 3 bolt plate |
: I searched for a while just to find a z-bar for : my '65. I'm still looking for the 3 bolt : plate that attaches to the fender for the : pivit bolt (Hint, hint). It should weld up : as good as new. Faster and shouldn't cost : much. Just my 2c... : : Mike Don't know about the Z-bar, but the 3-bolt plate should still be floating around the garage, want me to look for it tonight? matt- mhaskell@reliant.com |
| Author: | Mike Andreas [ Thu Dec 20, 2001 8:40 am ] |
| Post subject: | Re: 3 bolt plate!!!!!! |
: Don't know about the Z-bar, but the 3-bolt : plate should still be floating around the : garage, want me to look for it tonight? : : matt- ABSOULTELY!!! I've missed a couple at my local Pick-A-Part. That and a hump and I think I'm done. Mike MAndreas@aol.com |
