It is currently Wed Nov 25, 2026 9:16 pm
PostPosted: Mon Jul 28, 2008 8:44 am
Site Admin
The target vehicles:
'71 Dart is the vehicle needing the new power steering.
'74 Valiant is the donor.
The pitman arm is different. It comes up from the bottom with the retaining nut on top of the center link in the '71.
The spline size on the '71 is smaller for the pitman arm. The '71 pitman arm will not install on the '74 box.
Now we are looking at using the pump from the '74 with the '71 box. It looks like it will work. The '71 pump has the Round shaped reservoir, while the '74 has the taller tapered reservoir. We have brackets for both installations.
Any thoughts?
CJ
PostPosted: Mon Jul 28, 2008 10:12 am
If the '71 steering box is good then use it with the rest of the parts from the '74. Otherwise you can swap in the '74 steering box if you use the '74's center link.
PostPosted: Mon Jul 28, 2008 10:49 am
Site Admin
Anybody local have a '74 centerlink? :D
CJ
PostPosted: Tue Jul 29, 2008 1:07 am
Site Admin
THOR is on the way home with functional power steering! :D
Thanks Josh!
CJ
PostPosted: Tue Jul 29, 2008 9:13 am
Sweet! Which gearbox did you use?
PostPosted: Tue Jul 29, 2008 11:29 am
Site Admin
His old one.
I haven't heard back from him yet. It was late! Hopefully his court date for the seat belt frackus went well!
CJ
