| forward or reverse valvebody? https://slantsix.org/forum/viewtopic.php?t=30312 |
| Author: | darrt wells [ Thu Jul 31, 2008 6:09 pm ] |
| Post subject: | forward or reverse valvebody? |
ya im looking into buying a hurst quarter stick shifter for my 68 dart with a stock 904 trans. Im just not sure wether i need to buy the forward or reverse valvebody shifter. |
| Author: | Joshie225 [ Thu Jul 31, 2008 6:23 pm ] |
With a stock valve body you want the forward pattern shifter. Only with a reverse pattern full manual valve body do you want the reverse pattern shifter. |
| Author: | darrt wells [ Thu Jul 31, 2008 6:30 pm ] |
is it hard to swap in a valvebody, and what has to be done? |
| Author: | slantzilla [ Fri Aug 01, 2008 9:47 am ] |
Depending on what valve body you get, some are a simple bolt in while other require holes drilled in drums, servos blocked, etc.. |
| Author: | CARS [ Fri Aug 01, 2008 9:01 pm ] |
A funny related story... My brother just installed a reverse valve body with a trans brake this season in his muskrat drag car. His shifter had the trans brake button in the T of the handle. The first time he launched, he let go of the button and bam! He shifted into second gear Later that day we wired in a second switch |
| Author: | slantzilla [ Fri Aug 01, 2008 9:23 pm ] |
Quote: A funny related story...
Mine's on the steering wheel just for that exact reason. My brother just installed a reverse valve body with a trans brake this season in his muskrat drag car. His shifter had the trans brake button in the T of the handle. The first time he launched, he let go of the button and bam! He shifted into second gear Later that day we wired in a second switch |
