It is currently Sat May 16, 2026 8:57 pm
PostPosted: Fri Aug 01, 2008 2:30 pm
Anyone have a part # and/or source for the thermostatic spring used on the heat riser valve on the exhaust manifold? Car is a '74 Dart w/1bbl carb. Have found some repair kits with counterweight, butterfly valve, shaft, and spring, but cost is $80-$90. I just need the spring. Thanks for any info!
