It is currently Mon May 25, 2026 7:59 am
PostPosted: Fri Aug 01, 2008 2:30 pm
Anyone have a part # and/or source for the thermostatic spring used on the heat riser valve on the exhaust manifold? Car is a '74 Dart w/1bbl carb. Have found some repair kits with counterweight, butterfly valve, shaft, and spring, but cost is $80-$90. I just need the spring. Thanks for any info!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
