| Timing qustion? https://slantsix.org/forum/viewtopic.php?t=30343 |
| Author: | tuffone20 [ Sat Aug 02, 2008 4:31 pm ] |
| Post subject: | Timing qustion? |
I think the timing might be off a little on our 74 Duster and am going to checking it today, but I'm not sure what it should be set at? I had the carb rebuilt and now I'm having a problem with it wanting to Diesel when I turn it off? Thanks for any help you can give me. |
| Author: | DusterIdiot [ Sat Aug 02, 2008 9:40 pm ] |
| Post subject: | Stock? |
Stock 1974 distributor should be set at TDC initial, and at highway RPMs with stock vacc. can you're at about 28-32 degrees of advance...tops... -D.idiot |
| Author: | tuffone20 [ Sun Aug 03, 2008 1:13 am ] |
Thanks for the info I'll check it and see where it is. |
