It is currently Thu Nov 26, 2026 12:52 am
PostPosted: Thu Dec 27, 2001 7:26 am
Does anyone know if the mouldings from a '66 Valiant V-200 4 door sedan will fit a '66 Valiant V-200 Wagon?
theluketribe@hotmail.com
PostPosted: Thu Dec 27, 2001 9:18 am
: Does anyone know if the mouldings from a '66
: Valiant V-200 4 door sedan will fit a '66
: Valiant V-200 Wagon?
I had a '66 V200 wagon and believe that they are identical to the 4dr sedan at least from the rear door forward. The quarter panel behind the rear door may be slighly different from the sedan as it is really the same as those on the '63 to '65 wagons.
But maybe you should consider what I did which was to remove the trim and patch up the mounting holes prior to a repaint. The '66 looks really clean de-chromed. I made mine into a "Barragon" with a Barracuda grill and wheel covers. Love those wagons!
PatGR@mediaone.net
