It is currently Mon Nov 30, 2026 10:08 am
PostPosted: Sun Aug 03, 2008 5:07 pm
I ran across an article on BigBlockDart.Com (http://www.bigblockdart.com/techpages/abconv.shtml) that said it would show you how to use a long A833 in an A body.
What it actually showed was an adapter to move the shifter mount from the long cone/rear position to a short cone/rear position. A plate steel mount extension.
It seems to me that this would merely make it possible to install a short model linkage on a long model tranny with the shifter half way between the forward mounting position and the rear mounting position on a long cone. I fail to see the great advantage of that. From what I've seen, short A833's are usually missing their linkage - at least on eBay, making them something to seek, not something you want to find uses for. And I don't see how that makes a long A833 fit into an A body better. (Maybe all long A833's fit under A bodies fine?!)
1. Does ANY configuration have a shifter in the forward mount position on the long A833, a position that would appear to work better with a bench seat than a midpoint position?
2. Have I missed the point of this article?
3. Is there any place where A833 linkages are "plentyful?"
Thanks
PostPosted: Mon Aug 04, 2008 11:10 am
The transmission mounting pad is also different between the long and short Mopar transmissions.
Save yourself a lot of fabrication work and trouble... get the correct lenght transmission for the chassis you are working with.
PostPosted: Mon Aug 04, 2008 11:26 am
rosskinder,
You asked: 1. Does ANY configuration have a shifter in the forward mount position on the long A833, a position that would appear to work better with a bench seat than a midpoint position?
Ans: Yes. I have 2 long model 833 OD's, both with a forward mount for the shifter. Mine are/were in a '64 d100 pickup and the shifter fits nicely in front of the bench seat. The rear mount would not work.
I can't see how the short body would ever work even with a S-shaped shift handle rod because the "throw" from R to 4th is so long the shift handle rod smashes into your dashboard, if not your seat. I made several shifter mounting plates to try angling the shfter body forward and backward to get it to fit the rods I had on hand. Easy enough to do from the forward mount holes, veeeery difficult to do from the rear ones.
As to getting rods, I made a recent post about rods to someone here...just like many things you will find them in the darndest places and at the darnedst times. Worth buying a Hurst Comp Plus with rods if less than $125 in my opinion just to get the rod set, then clean up the shifter and sell it.
rok
'64d100
rock
'64d100
PostPosted: Mon Aug 04, 2008 5:50 pm
Believe me, that is my intention. But finding the tranny I need has been pretty illusive.
Thanks
PostPosted: Tue Aug 05, 2008 8:25 pm
Thanks
http://cgi.ebay.com/ebaymotors/A833-Alu ... dZViewItem
http://cgi.ebay.com/ebaymotors/HURST-4- ... dZViewItem
http://cgi.ebay.com/ebaymotors/mopar-a- ... dZViewItem
PostPosted: Tue Aug 05, 2008 9:49 pm
Thanks
Lotsa bare-bones, stripped down, non-OD (wrong low gear ratio) trannies around. Everybody seems to strip and throw the goodies away.
Thanks
PostPosted: Wed Aug 06, 2008 10:35 pm
Actually, the first one I posted is an O.D version according to the info the seller posted.
Are you looking for a complete setup with everything you need to bolt into your car?
PostPosted: Thu Aug 07, 2008 5:21 pm
I think so. Replacing a 3 speed.
Thanks
