It is currently Fri Nov 27, 2026 2:52 am
PostPosted: Wed Aug 06, 2008 6:32 pm
i have a disc conversion off of a 73 cuda and was wondering what i will need to fit it on my 72 duster???
PostPosted: Wed Aug 06, 2008 8:12 pm
What conversion parts do you have? Please list everything.
Was the '73 'Cuda originally a disc brake car? Does your '72 Duster have 9" drum brakes?
'73 E-bodies used nearly the same front brakes as the '73 and later A-bodies, but we really need to know what you have for parts.
PostPosted: Fri Aug 08, 2008 4:16 pm
its 10in front drum on the 72 duster. its original disc on the 73 cuda.
i heard the only differance is that 72 has small dia. balljoint and the 73 is the large.
PostPosted: Fri Aug 08, 2008 5:30 pm
Right, you need the big ball joint upper control arm for your Duster. Of the 10" drum brake cars I believe only the '73 and later had the large upper ball joint. Everything else from the E-body should bolt on, but be careful with the brake hoses as they may or may not fit well. Don't forget a disc brake master cylinder.
