It is currently Sat Jun 13, 2026 5:13 am
 Post subject: Kick panel insulation
PostPosted: Tue Aug 12, 2008 6:56 pm
Well I got the vent box out (easier than I expected) and sucked another ton of rat's nest material out from the vent/cowl area (yay), but I also noticed that either the insulation was heavily deteriorated, or the rats were tearing it apart. Inspected the wires behind it, and luckily, still no damage. I want to put new insulation on the back of the kickpanel though. Something that the rats would be less inclined to chew up if there's such a material. What do you guys suggest?
PostPosted: Tue Aug 12, 2008 8:05 pm
I don't know for sure, but these '67-'69 kickboard insulation panels would probably suit your '74 just fine. Or if you're skittish about using other-year parts, check with REM Automotive. Call 'em up and ask for catalogue sheets applicable to your A-body Mopar.
PostPosted: Tue Aug 12, 2008 8:27 pm
industrial felt.
http://www.ctidirectory.com/search/comp ... pany=10918
