| Kick panel insulation https://slantsix.org/forum/viewtopic.php?t=30529 |
| Author: | Jopapa [ Tue Aug 12, 2008 6:56 pm ] |
| Post subject: | Kick panel insulation |
Well I got the vent box out (easier than I expected) and sucked another ton of rat's nest material out from the vent/cowl area (yay), but I also noticed that either the insulation was heavily deteriorated, or the rats were tearing it apart. Inspected the wires behind it, and luckily, still no damage. I want to put new insulation on the back of the kickpanel though. Something that the rats would be less inclined to chew up if there's such a material. What do you guys suggest? |
| Author: | SlantSixDan [ Tue Aug 12, 2008 8:05 pm ] |
I don't know for sure, but these '67-'69 kickboard insulation panels would probably suit your '74 just fine. Or if you're skittish about using other-year parts, check with REM Automotive. Call 'em up and ask for catalogue sheets applicable to your A-body Mopar. |
| Author: | steponmebbbboom [ Tue Aug 12, 2008 8:27 pm ] |
industrial felt. http://www.ctidirectory.com/search/comp ... pany=10918 |
