| Carter BBD Questions!!! Please Help!! https://slantsix.org/forum/viewtopic.php?t=30546 |
| Author: | dusterguy225 [ Wed Aug 13, 2008 7:04 pm ] |
| Post subject: | Carter BBD Questions!!! Please Help!! |
I am going to rebuild (oh what fun) my Carter BBD carb for my super six Also, what other things do I have to do to it, and/or be worried about? I want to get this thing done and on this weekend, so I want to be totally prepared. Thanks! Note: this thing looks like it hasn't been used in 10+ years, so I want to be thurough. |
| Author: | SlantSixDan [ Wed Aug 13, 2008 7:59 pm ] |
Here is the Carter BBD operation and repair manual (pdf) You can't go out and buy replacement carburetor bushings, which don't exist. Instead, you have the throttle body rebushed; see this post. |
| Author: | dusterguy225 [ Wed Aug 13, 2008 8:21 pm ] |
Thanks, that aught to come in handy! |
| Author: | dusterguy225 [ Fri Aug 15, 2008 4:25 pm ] |
| Post subject: | Umm, Problem |
I Took another look at the carb today, and just my luck, the mixture screws are missing! Any help is greatly appreciated. Thanks! |
| Author: | Aggressive Ted [ Fri Aug 15, 2008 8:10 pm ] |
The ones I have look like the taper is different between the two. However, you may get them to work. Never tried it....... I would get another BBD carb for parts to be safe! |
| Author: | dusterguy225 [ Fri Aug 15, 2008 8:35 pm ] |
Quote: I would get another BBD carb for parts to be safe!
Its quite hard to find BBD carbs these days. The one I came across was just extreamly good luck.
| Author: | Aggressive Ted [ Fri Aug 15, 2008 8:37 pm ] |
SL6 Dan has some nice new ones..... |
| Author: | dusterguy225 [ Sat Aug 16, 2008 2:54 pm ] |
Quote: SL6 Dan has some nice new ones.....
Do you mean the carbs or the screws?
| Author: | Aggressive Ted [ Sat Aug 16, 2008 8:28 pm ] |
Carbs, but he may have some screws as well. Send him a PM. |
| Author: | dusterguy225 [ Sat Aug 16, 2008 10:06 pm ] |
Quote: Carbs, but he may have some screws as well. Send him a PM.
Ok, I did. Thanks!
| Author: | vynn3 [ Sun Aug 17, 2008 10:04 am ] |
Quote: Its quite hard to find BBD carbs these days. The one I came across was just extreamly good luck.
Ummmm... ever check Ebay? BBDs are there ALL the time. I'm not sure if I'd trust one for use, but if you just need parts, that seems like the easiest way to go. Heck, if all you need is a parts carb, a 318 BBD would be fine, and there's a MILLION of those out there.
| Author: | dusterguy225 [ Sun Aug 17, 2008 1:27 pm ] |
Quote: Ummmm... ever check Ebay? BBDs are there ALL the time. I'm not sure if I'd trust one for use, but if you just need parts, that seems like the easiest way to go. Heck, if all you need is a parts carb, a 318 BBD would be fine, and there's a MILLION of those out there.
I have checked ebay, and they are all quite expensive, and I only need the mixture screws, not the whole carb, but maybe worth a try.
| Author: | dusterguy225 [ Sun Aug 17, 2008 7:50 pm ] |
As I suspected, pretty expensive. I will keep on tryin though. |
