It is currently Sun May 17, 2026 4:28 am
PostPosted: Wed Aug 13, 2008 7:04 pm
I am going to rebuild (oh what fun) my Carter BBD carb for my super six :P and I was wondering about these throttle bushings I have heard about. How do I replace them, or do I even have to? The throttle doesn't have any play in it, so im guessing its ok. :?:
Also, what other things do I have to do to it, and/or be worried about? I want to get this thing done and on this weekend, so I want to be totally prepared.
Thanks! :D
Note: this thing looks like it hasn't been used in 10+ years, so I want to be thurough.
14" Cragar SS wheels
PostPosted: Wed Aug 13, 2008 7:59 pm
Here is the Carter BBD operation and repair manual (pdf)
You can't go out and buy replacement carburetor bushings, which don't exist. Instead, you have the throttle body rebushed; see this post.
PostPosted: Wed Aug 13, 2008 8:21 pm
Thanks, that aught to come in handy!
 Post subject: Umm, Problem
PostPosted: Fri Aug 15, 2008 4:25 pm
I Took another look at the carb today, and just my luck, the mixture screws are missing! :evil: Can anybody tell me where I can find these? Auto parts stores don't seem to have them. Will two 1 bbl screws work? :? I have those.
Any help is greatly appreciated. Thanks!
PostPosted: Fri Aug 15, 2008 8:10 pm
The ones I have look like the taper is different between the two. However, you may get them to work. Never tried it.......
I would get another BBD carb for parts to be safe!
PostPosted: Fri Aug 15, 2008 8:35 pm
Its quite hard to find BBD carbs these days. The one I came across was just extreamly good luck.
PostPosted: Fri Aug 15, 2008 8:37 pm
SL6 Dan has some nice new ones.....
PostPosted: Sat Aug 16, 2008 2:54 pm
Do you mean the carbs or the screws?
PostPosted: Sat Aug 16, 2008 8:28 pm
Carbs, but he may have some screws as well. Send him a PM.
PostPosted: Sat Aug 16, 2008 10:06 pm
Ok, I did. Thanks!
PostPosted: Sun Aug 17, 2008 10:04 am
Ummmm... ever check Ebay? BBDs are there ALL the time. I'm not sure if I'd trust one for use, but if you just need parts, that seems like the easiest way to go. Heck, if all you need is a parts carb, a 318 BBD would be fine, and there's a MILLION of those out there.
vm
PostPosted: Sun Aug 17, 2008 1:27 pm
I have checked ebay, and they are all quite expensive, and I only need the mixture screws, not the whole carb, but maybe worth a try.
PostPosted: Sun Aug 17, 2008 7:50 pm
As I suspected, pretty expensive. I will keep on tryin though.
