It is currently Sat May 23, 2026 7:30 pm
PostPosted: Thu Aug 14, 2008 9:43 am
Hi there!
I wanted to put a HEI module in my Coronado. I have the original mopar module... but it didn´t work anymore... so.. i took the one in my GTX and it was working fine... but since I live in Argentina.. I can´t replace the original module easy... so I think changing to HEI was a good move.
The car was starting inmmediatly... no matter if the engine was cold or hot.
I took the 2 cables from the pick up and connected it to terminals W and G.
I took coil terminal + and placed it to the terminal B
I took coil terminal - and placed it to the terminal C
The engine didn´t start.
I placed battery + to the coil + so there is 12V everywhere... It didn´t start.
I inverted the W and G terminals... and it still doesn´t start... no spark.
Any idea????
Does the module have to be placed to ground??? it was in the air. Just for testing... the only thing i can think of....
PS: I have two modules.. one made in usa.. and one made in china.... all testing was done with de USA one.
PostPosted: Thu Aug 14, 2008 9:52 am
Online
The back of the HEI module must be grounded. Nice looking cars by the way!
PostPosted: Thu Aug 14, 2008 9:55 am
If you look at the bolt holes on the module you will see there is a ground strap built into one of them. The screw going through that hole grounds the module. Some folks put a ring terminal and ground wire there. The back of the module needs to be attached to a heat sink with heat sink compound or the module will overheat and possibly burn up.
PostPosted: Thu Aug 14, 2008 10:03 am
Remember to bypass the ballast resistor
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Aug 14, 2008 2:12 pm
Yeap! Problem solved... Was a ground problem!
Its working perfect.. even with the 0.6 ohm resistor! =)
Thanks for the help!
PostPosted: Thu Aug 14, 2008 2:29 pm
Bypassing the resistor will help the performance. The HEI module controls the coil current so the ballast resistor is not required.
PostPosted: Thu Aug 14, 2008 4:37 pm
Excelent!!! I hate resistors!
Spark is ¨longer¨ now!
Next step: Place the MSD 6AL.
