It is currently Fri May 22, 2026 12:28 am
PostPosted: Thu Aug 14, 2008 2:09 pm
I have a rebuilt 225 in 67 dart, new Holley 64-3111 from summit; ran Ok when installed, had a few hassles ---New oil pumps with powder metal drive gears are NG junk, gear slipped , lost all pressure, but did not hurt it--saw light and stopped . You cannot "press on" powder metal !! Lame attempt by rebuilder to make it work by knurling drive input shaft. Steel gear only..warning!
Pushrod end cup broke off , exhaust , backfire every turn, unreal how violent. Has DC slant six ignition conversion
Now when I floor it, 8K later, i get a big moan and it goes no where ; when accellerating, almost feels like missing but it is not. feeling is like "it won't take the gas", lifting a little seems to make more torque. Any ideas? Tapped out of em! checked fuel supply, power valve (from backfire issue) seems ok..PV diaphram OK , but kind of a crummy fit in carb , no guide in bowl. Are they like that? Ignition all new, should be fine, does not seem like ignition issue . No points
This account is used for member help ONLY!
PostPosted: Thu Aug 14, 2008 3:13 pm
The DC (MP) electronic ignition conversion kit includes a distributor with an "all in, right now" advance curve very poorly suited for street use. You'll want to recurve the distributor or swap in a different one. A carb with a number starting "64-" is not new, it is "remanufactured", with all the many problems that brings.
PostPosted: Thu Aug 14, 2008 7:43 pm
Are you a registered member of the site? If not please register, and log in, to post questions. The "userhelp" name is for use when a registered member is haveing a problem logging in, not for asking auto related repair questions. Thanks.
PostPosted: Thu Aug 14, 2008 10:41 pm
you got ME confused Charlie." userhelp" is the posters board name and he has to be logged in to post anything in the first place ? does'nt he?
Slant Six forum must have accepted "userhelp" as a legitimate board user name - so what is the problem you see?
I am confuddled by your comments.
regards,Rod :? :D
PostPosted: Thu Aug 14, 2008 11:33 pm
No, "userhelp" is the account set up specifically for use by those having trouble logging onto their accounts or getting their account registrations validated.
PostPosted: Fri Aug 15, 2008 12:24 am
Dan,(and Charlie),thanks for eddy- ficating me on the intricacies of this board. never had trouble logging in so never needed to know that userhelp thing.
they say you learn something new every day - well I did.
thanks guys. much embarassings! :oops:
regards,Rod :D
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
