It is currently Sun May 17, 2026 11:28 pm
 Post subject: 904 converter question
PostPosted: Sun Aug 17, 2008 9:51 am
Hello all, I was wondering.Is the LA 904 converter the same as the slant 6 904 converter? Is the flex plate mounting the same? I ask because I was looking at a higher stall speed, and didnt see anything about small block or slant 6 spacific. Thanks for the info!!! I am hraded out to pull the 4 speed in my 67, and replace it w/ a rebuilt one.....w/o broken shifting forks.LOL
Andrew
Wife's: 64 Valiant
My: 70 Road Runner, 67 Barracuda, AND the 62 Valiant drag car!!
PostPosted: Sun Aug 17, 2008 9:54 am
The converters interchange as long as they have the correct nose and splines. The '68 and later converters are bigger of nose and larger of input shaft with more splines.
PostPosted: Sun Aug 17, 2008 10:03 am
Just remember, a converter for a v-8 will will stall less on a slant. Most converters have a stall speed rated for a v-8. If you see a 3,000 rpm converter, it will stall less on a slant, maybe only 2,500. The torque of the engine will have a large effect on stall speed. I have a race convereter that has a 3200 stall speed on my 170 engine, but will stall 4,000 with my 225. That same converter would probably stall over 5,000 with a 360 engine.
PostPosted: Sun Aug 17, 2008 11:39 am
Thanks.my engine in the 62 is a 68, and the trans is a 72......or a 74, cant remember.LOL THanks for the info......and thanks for letting me know about the stall speed changing. Thats what scares me about a stall.....would like to buy a used one thatis a known speed, and to get me by for now till I change the engine.
Andrew
Wife's: 64 Valiant
