It is currently Mon Nov 23, 2026 1:19 pm
 Post subject: K-frame bolts
PostPosted: Mon Aug 18, 2008 9:35 pm
Is there a source for K-frame bolts (the four that bolt the k-frame to the frame rails). Is there a torque spec for these?
PostPosted: Mon Aug 18, 2008 10:50 pm
6 Pack Dart
I would use grade 8 bolts and nuts. Then follow the recomended torque specification for the diameter of the bolt.
PostPosted: Wed Aug 20, 2008 6:08 pm
Better look for some originals. They are shouldered and a regular bolt wont center up and locate the k-frame correctly.
I hit the wrecking yards and grabbed a couple out of each car when I need a set for my sectioned k-frame project.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Thu Aug 21, 2008 8:06 am
Thanks, I found a couple of Darts and Dusters yesterday at a junkyard and pulled a couple. They came out of the junkyard car a lot easier than mine did.
