| K-frame bolts https://slantsix.org/forum/viewtopic.php?t=30626 |
| Author: | RDJ [ Mon Aug 18, 2008 9:35 pm ] |
| Post subject: | K-frame bolts |
Is there a source for K-frame bolts (the four that bolt the k-frame to the frame rails). Is there a torque spec for these? |
| Author: | Fopar [ Mon Aug 18, 2008 10:50 pm ] |
I would use grade 8 bolts and nuts. Then follow the recomended torque specification for the diameter of the bolt. |
| Author: | DionR [ Wed Aug 20, 2008 6:08 pm ] |
Better look for some originals. They are shouldered and a regular bolt wont center up and locate the k-frame correctly. I hit the wrecking yards and grabbed a couple out of each car when I need a set for my sectioned k-frame project. |
| Author: | RDJ [ Thu Aug 21, 2008 8:06 am ] |
Thanks, I found a couple of Darts and Dusters yesterday at a junkyard and pulled a couple. They came out of the junkyard car a lot easier than mine did. |
