It is currently Wed May 20, 2026 2:26 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: 71 valiant 4 door CHEAP
PostPosted: Fri Jan 04, 2002 10:40 pm
i took off the parts i want to keep ( front disc brakes, rear brakes, carb, alternator, and distributor). this car has ZERO RUST and was a runner before i took the parts off. I need the space so it has to go! $300 OBO. 1971 Valiant, 4 door, Green/Green, 225 slant, auto transmission shifted perfectly. Manual steering, manual brakes. body a little rough in back. Save it from the crusher! thanks.
ksjo923@hotmail.com
PostPosted: Sat Jan 05, 2002 9:15 am
Where is the car located? Does it "roll"? (can it be towed on 4 wheels)
: I took off the parts i want to keep ( front
: disc brakes, rear brakes, carb, alternator,
: and distributor). this car has ZERO RUST and
: was a runner before i took the parts off. I
: need the space so it has to go! $300 OBO.
: 1971 Valiant, 4 door, Green/Green, 225
: slant, auto transmission shifted perfectly.
: Manual steering, manual brakes. body a
: little rough in back. Save it from the
: crusher! thanks.
PostPosted: Sat Jan 05, 2002 10:52 am
: Where is the car located? Does it
: "roll"? (can it be towed on 4
: wheels)
: DD
The car is located in Campbell, CA ( right next to San Jose.) Yes it can be towed on 4 wheels because i have an extra set of small bolt rotors i am going to put on it so it can roll.
PostPosted: Sat Jan 05, 2002 1:28 pm
I found a '73 4-door this afternoon, I paid $200 for it to save it from the crusher. It is missing the front bumper, grill, and radiator, gas tank but is very rust free. Has minor 'yard dents in front fenders. It's a pretty little Valiant that needs a good home. Has the factory stainless door edge guards, 225, aftermarket a/c, auto, but only drum brakes. Appears to be a low miles car.
I might keep it as has current tags, if anyone in South texas might be interested I'd sell it for less than I paid for it. I already have 3 slant A-bodies! This Valiant could be a great sleeper project.
: i took off the parts i want to keep ( front
: crusher! thanks.
tkeith@mindspring.com
