It is currently Thu May 14, 2026 3:24 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
 Post subject: propane
PostPosted: Fri Jan 11, 2002 8:18 pm
I never have owned a propane powered car but seams like a good idea. I have read on here that some of our forien friends use it. I just wonder what it would be like to use it on a /6. I wonder about consistency at the drag strip? I will never be the fastest but consistent numbers get the trophys.
melam@nxs.net
 Post subject: Propane and N2O
PostPosted: Fri Jan 11, 2002 9:21 pm
I talked to a guy at Clifford a couple of weeks ago who says he runs propane and nitros in a 14:1 compression Ford inline 6. He has it set up to run on gas through a carb and when he wants to race he shuts off the gas and turns on the propane. Sounds kind of crazy but he says it works. To each his one I guess
Mike
MAndreas@aol.com
 Post subject: Re: propane *PIC*
PostPosted: Sat Jan 12, 2002 9:21 am
I run my 1987 Slant 6 truck on propane. The propane mixer just sits on top of the gasoline carburetor in place of the air filter housing. the propane mixer is inside the air filter you see in the picture. A selector switch in the cab operates electric solenoid valves to select eithter propane or gasoline.
cfield@ll.net
PostPosted: Sun Jan 13, 2002 3:28 pm
: I run my 1987 Slant 6 truck on propane. The
: propane mixer just sits on top of the
: gasoline carburetor in place of the air
: filter housing. the propane mixer is inside
: the air filter you see in the picture. A
: selector switch in the cab operates electric
: solenoid valves to select eithter propane or
: gasoline.
Hay craig does it run better on the propane or gas?
melam@nxs.net
PostPosted: Sun Jan 13, 2002 4:05 pm
: Hey craig does it run better on the propane or
: gas?
Runs the same either way except for cold engine driveability and warm up. With propane you don't have the spit-sputter, engine dies when you put it in gear problems you do with gasoline. No hesitation problems either. Runs just like a modern vehicle with fuel injection.
Also the 105 or so octane of propane got rid of my detonation problem.
cfield@ll.net
PostPosted: Sun Jan 13, 2002 5:35 pm
: Runs the same either way except for cold engine
: driveability and warm up. With propane you
: don't have the spit-sputter, engine dies
: when you put it in gear problems you do with
: gasoline. No hesitation problems either.
: Runs just like a modern vehicle with fuel
: injection.
: Also the 105 or so octane of propane got rid of
: my detonation problem.
Craig where can I buy the propane carb or kit or whatever? by the way thanks for the responce.
melam@nxs.net
PostPosted: Sun Jan 13, 2002 8:12 pm
: Craig where can I buy the propane carb or kit
: or whatever? by the way thanks for the
: responce.
I got all the stuff from a local guy who has been in the propane engine/automobile conversion business for many years. I installed everything myself and went back to him so we could use his exhaust gas anlyzer to adjust the fuel ratios.
A propane conversion is not generaly recommeded as a do-it-yourself project.
Check out the Impco website at <A HREF="http://www.ibuild.ws/">http://www.ibuild.ws/</A> . My propane mixer and vaporizer are Impco brand.
Also look at <A HREF="http://wps.com/LPG/LPG-book-final.html" ... al.html</A> for more info. Also search the internet. Your local public library may have or can get some books on the subject too.
cfield@ll.net
PostPosted: Mon Jan 14, 2002 9:14 am
: I got all the stuff from a local guy who has
: been in the propane engine/automobile
: conversion business for many years. I
: installed everything myself and went back to
: him so we could use his exhaust gas anlyzer
: to adjust the fuel ratios.
: A propane conversion is not generaly recommeded
: as a do-it-yourself project.
: Check out the Impco website at
: <A HREF="http://www.ibuild.ws/">http://www.ibuild.ws/</A> . My propane mixer
: and vaporizer are Impco brand.
: Also look at
: <A HREF="http://wps.com/LPG/LPG-book-final.html" ... al.html</A> for
: more info. Also search the internet. Your
: local public library may have or can get
: some books on the subject too.
I have a comlpete propane system, that was salvaged from a Ford pickup with a 302 V-8. The mixer is a direct bolt on, in place of a Ford or Holley 2 bbl carb. My original plan was to try it with my turbo slant. However I never got that far.
P.S. as a related thought. How about doing away with the vaporizer and mixer, and injecting liquid propane,with fuel injectors right into the manifold runners. With the aftermarket programable ECM units, it might be possible. This would also take advantage of the cooling effect. Then add a nitrous fogger system. Sounds interesting to me.
Charlie The worlds greatest procrastinator
flturbo6@aol.com
PostPosted: Mon Jan 14, 2002 9:28 am
: P.S. as a related thought. How about doing away
: with the vaporizer and mixer, and injecting
: liquid propane,with fuel injectors right
: into the manifold runners. With the
: aftermarket programable ECM units, it might
: be possible. This would also take advantage
: of the cooling effect. Then add a nitrous
: fogger system. Sounds interesting to me.
: Charlie The worlds greatest procrastinator
Hi Charlie,
Actually there is a place here in Minnesota already doing that. Check out <A HREF="http://www.bi-phase.com/">http://www.bi-phase.com/</A>
cfield@ll.net
