It is currently Mon Nov 23, 2026 8:44 pm
 Post subject: piston ring brands
PostPosted: Fri Sep 12, 2008 6:34 pm
well i have been looking @ all brands of piston rings to buy and i am confused! I hear that sealed pwr rings are pretty good but 2 store chains are out of stock. what i can get are hastings, cleavite and high tek. i have heard very bad things about high tek. so tomorrow i place my order for piston rings. what brand would you u guys put in your car and why?
because i plan on these being in use for a long while and now is a good time to get the proper ones.
thanks.
neil parker - aka MiDi
PostPosted: Fri Sep 12, 2008 8:33 pm
I would use Hastings moly rings for an engine I expect to see many years of service. If the engine likely won't see a lot of miles or may get into detonation a little then I would use plain or chrome rings as they will still last a long time and detonation won't take out the moly. For a highly boosted engine then start looking at ductile or stainless rings.
PostPosted: Fri Sep 12, 2008 8:34 pm
Well, FWIW, when I rebuilt the 400 I had in my '70 Fury in '92, I used Sealed Power cast iron rings. I used cast iron instead of moly rings because the iron rings seat faster than moly (or so I was told). To be honest, I really didn't do a proper break in, just started driving it like normal. Never smoked. I replaced the heads in '99 due to a couple of bad valves, and the cylinders still had the cross hatch pattern and good compression. Still ran great when I sold the engine in 2000 (drunk driver totaled the car and my lower back in late '99).
PostPosted: Fri Sep 12, 2008 9:00 pm
Moly actually seats quite easily. Chrome rings are relatively more difficult to seat.
PostPosted: Fri Sep 12, 2008 9:05 pm
thanks for the info.
the engine is stock (w/ super six & headers) and will be a daily driver with a few passes on the drag strip for fun. so i am looking for somthing that will hold up well for years of use.
the hastings seem the cheapest, next in price is the clevites.
also i am wondering what rod bearings i should get cleavite or sealed power. i have cleavite 77 main bearings in there now. is it ok to have one brand of rod bearings and another brand of main bearings?
Users browsing this forum: Google [Bot] and 8 guests
