It is currently Sun Nov 29, 2026 6:56 am
PostPosted: Sat Sep 13, 2008 9:06 pm
Started taking apart my front suspension today to rebuild and change over to front Disc brakes when I tried to take out my Idler arm bolt it hits the oil pump :x .Is there any trick to get this out or do I have to raise the engine or take off the oil pump? thanks Richard
my first 6 1973 Plymouth DusterImage
PostPosted: Wed Sep 17, 2008 1:47 pm
I haven't quite seen your problem, but lifting an engine a few inches usually isn't too hard; most things have enough give; just remember to unbolt the fan shroud 1st.
