It is currently Sat Nov 28, 2026 9:22 pm
 Post subject: End links
PostPosted: Mon Sep 15, 2008 11:06 am
I wanted to install my Addco front sway bar and am needing the end links. Can they be gotten over the counter>? Can i use a v-8 valiant as a reference for the parts guy as they had sway bars? Regular rubber busihngs are fine in this application. (63 wagon,slant of course)
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Sep 15, 2008 1:28 pm
Addco has different mounting geometry than stock. You can get the endlinks from Summitracing.com or similar, or local parts store, just need to know length. IIRC, my Addco bars have used about a 1.5" spacer between the bushings and maybe a 6" bolt?
