| Bolt pattern- 4"=3 13/16"??? https://slantsix.org/forum/viewtopic.php?t=31132 |
| Author: | stonethk [ Tue Sep 16, 2008 8:00 am ] |
| Post subject: | Bolt pattern- 4"=3 13/16"??? |
It seems like I always run into these type of technicalities. So I have a 5 SBP (1/2" bolts =small?). When I measure the lugs center to center they are about 3 13/16 " + Is this the nominal measurement for a 4 inch pattern? Or does 4 inch represent the overall diameter measurement as opposed to the cross measurement distance to the bolts? Doofus here from planet Boltulon. |
| Author: | emsvitil [ Tue Sep 16, 2008 10:53 am ] |
A 4" diameter circle will have the center of each bolt on it. The approx. measurement between 2 bolts is about 4" center to outside when you have 5 bolts. |
