It is currently Sat Nov 28, 2026 10:30 pm
PostPosted: Tue Sep 16, 2008 8:00 am
It seems like I always run into these type of technicalities.
So I have a 5 SBP (1/2" bolts =small?).
When I measure the lugs center to center they are about 3 13/16 " +
Is this the nominal measurement for a 4 inch pattern?
Or does 4 inch represent the overall diameter measurement as opposed to the cross measurement distance to the bolts?
Doofus here from planet Boltulon.
PostPosted: Tue Sep 16, 2008 10:53 am
A 4" diameter circle will have the center of each bolt on it.
The approx. measurement between 2 bolts is about 4" center to outside when you have 5 bolts.
