It is currently Sat Nov 21, 2026 10:49 pm
 Post subject: Header Question
PostPosted: Thu Sep 18, 2008 10:08 pm
I have some Slant 6 Headers, and I heard that there were two different kinds made, car and truck, so i was wondering, how do I tell the difference?
From there, how difficult is it to swap the manifold to the headers? Does the intake come off?
Are there exhaust gaskets that I'd have to buy? What else would I need?
Any tips or other info is appreciated, thanks everyone.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Fri Sep 19, 2008 7:58 pm
What do they look like? Do you have any pic's?
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Sun Sep 21, 2008 7:55 pm
They look like this:
Or possibly like this:
The guy I got them from siad they were on his son's 63 Dart.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sun Sep 21, 2008 10:00 pm
I'd say the first pic is correct the big bends are to clear the stater.
PostPosted: Sun Sep 21, 2008 10:01 pm
They sure do look long.
PostPosted: Mon Sep 22, 2008 5:41 am
Those are the "old" style Cliffords, for the 66 older "A" bodies. They are almost impossible to find. There were two different versions. One for the 225 engine, and one for the 170 engine. There is a small difference in the length, due to the difference in the hight of the engines. It is very hard to tell the difference, just by looking at them. If you don't use them, I would be interested in buying them.
 Post subject: Re: Header Question
PostPosted: Mon Sep 22, 2008 5:49 am
yes, the intake has to come off
you will need intake/exhaust gasket. Will have to have the exhaust system modified to connect to the headers.
These headers will help, even on a stock engine, but the front pipes go down thru the "K" member, then turn to the rear. They hang pretty low, and can hit the ground on bumps. Clifford's old catalog, actually says, "14 wheels required".
Any tips or other info is appreciated, thanks everyone.[/quote]
PostPosted: Mon Sep 22, 2008 9:17 am
Helps build torque 8)
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Sep 22, 2008 11:37 am
Be sure to put a straight-edge across the port flanges to be sure they are flat. I have had many sets of tube steel headers where this surface was way-off and no gasket would ever seal.
PostPosted: Mon Sep 22, 2008 9:49 pm
That's what I figured.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Sep 22, 2008 9:51 pm
Will either one work for my car? It has a 225 in it now.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Sep 22, 2008 9:53 pm
Modifying the exhaust is no problem. Can I get the gaskets anywhere? Not too woried about hitting the ground, but eventually, I will go to 14 inch wheels.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Sep 22, 2008 9:54 pm
Be sure to put a straight-edge across the port flages to be sure they are flat. I have had many sets of tube steel headers where this surface was way-off and no gasket would ever seal.
I'll be sure to check it out.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Tue Sep 23, 2008 5:37 am
You have to have the correct ones for the engine. They are most likely for the 225. The only 170 ones I have seen, are the ones Jack made for me, back in the '70's. I have seen 225 ones show up at swap meets and on line, so it seems like there were more of the 225 ones made. The only way to tell for sure is to try them.
PostPosted: Tue Sep 23, 2008 7:06 am
Go with the Remflex gaskets,with the headers it will take up some warping,twisting etc of the flange area.I'd do a "dry"fit to make sure the headers are correct and clear eveything,then bend,hammer what ever.When its good to go then on with the Remflex dot com,some napa stores will order them for you or go direct.Good folks there and AWESOME gasket :D
