It is currently Fri Nov 20, 2026 9:07 pm
PostPosted: Sun Sep 28, 2008 7:46 am
Can removal of the spring & piston be performed with the oil filter in place without having an oil drain-down mess? Or, is this best performed with the oil filter removed?
PostPosted: Sun Sep 28, 2008 9:45 am
I'd do it with the oil filter removed to avoid just such a mess.
PostPosted: Sun Sep 28, 2008 10:33 am
Personal preference here, we all do it differently.
I've done it a great many times with the oil filter attached. Even if you remove the oil filter, you still get a bit of a mess when the filter comes off the pump. If you leave the filter in place, it will only drain down through the relief area, where it's centralized, and you can simply put a pan under it.
Question: Why are you taking it apart? Is your oil pressure low?
~THOR~
PostPosted: Sun Sep 28, 2008 10:43 am
He's taking it apart because it is routine maintenance usually neglected decades past its due-date.
PostPosted: Sun Sep 28, 2008 10:44 am
That's a great reason!!!
~THOR~
PostPosted: Sun Sep 28, 2008 11:02 am
At what mileage does this have to be done? Every 20,000?
PostPosted: Sun Sep 28, 2008 11:14 am
THOR,
I picked this car up this past March, and don't know the history. The valve cover had been recently decrudded before I got the car. The top of the head was clean no sludge, and the oil is showing a darkening now that I driven 1500 miles or so this summer.
Even though the oil pressure light only comes on when cranking the engine, and no excess clatter exhibited at idle after a good warm up. I figured what the heck, I'll check it out, and get the oil changed.
PostPosted: Sun Sep 28, 2008 11:28 am
Oh, y'know, every thirty years or so, whether it needs it or not :lol:
Seriously, every couple years ought to be plenty.
PostPosted: Sun Sep 28, 2008 7:01 pm
By the way the FM recommended #400 wet/dry paper to clean the barnacles off the piston if needed, and be very careful not to round off any of the sharp edges in the process. If the edges were rounded, toss it out and buy a new piston.
PostPosted: Sun Sep 28, 2008 7:05 pm
Let us know how yours looks when you take it apart. If it smooth or if it is scratched up or growing barnacles.....
PostPosted: Sun Sep 28, 2008 8:59 pm
What happens to the oil pressure relief valve so that you have to take it apart?
PostPosted: Sun Sep 28, 2008 9:27 pm
Ed, you're a relatively longtime, relatively advanced member of this community. Please set a good example for the newbies — and give your fingers some good exercise — by making use of this board's convenient search function.
PostPosted: Sun Sep 28, 2008 9:50 pm
Tried a few times and got
'Debug mode'......................
So I asked :roll:
edited:
searched finally worked.
thread 0, which led to
thread 1, thread 2.
and now I vaguely remember :oops:
PostPosted: Sun Sep 28, 2008 10:12 pm
Never hurts to have a look see anyways! Be great if you could post some pics too.
~THOR~
PostPosted: Mon Sep 29, 2008 6:56 am
As requested...
The device was scratch free, and spotless.
Two minutes to remove the spring and entrails, 30 minutes to get the jack, wrench, camera, carb cleaner, and the right glasses...
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
