It is currently Sat Dec 27, 2025 4:44 am
Post new topic  Reply to topic  [ 95 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Mon Oct 06, 2008 5:05 am
hey all
on sunday i forked out the cash and got one of those new 4 bbl intakes from aussie speed ..
it looks nice and i post more stuff on the fourm
and at the presant i am running a 500 edelbrock on a cain 4BBL intake its quite short , on 230mm long from head to outer alloy edge . the new one is about 470 long
with very even runner lenght and VERY good casting . no clean up required at all ..
the cain inake has very uneven runners . and is a litte bit like a adaptor then a manifold .. so in the next few weeks i will fit it and reply if theres any questions i can answer please add to this thread ..
yours a happy sheep ..
the black sheep
i like it lumpy
PostPosted: Mon Oct 06, 2008 5:19 am
Glad to hear it, Mr. Sheep. Let us know how it works out...
PostPosted: Mon Oct 06, 2008 9:39 am
Some "before and after" time slips would be cool. 8)
PostPosted: Mon Oct 06, 2008 9:56 am
Poser
Black Sheep thanks for the post. I too have a hurricane and will be following this thread. You car/project sounds much farther along than mine, so I am looking foward to your feedback on fitment, carb orientation, tuning, divided plenum? etc. Thanks, Wayne.
PostPosted: Mon Oct 06, 2008 10:13 am
i have been dying to get the aussie speed long runner 2bbl intake.
so please tell us how it works out, cause soon as i can afford one i am getting the 2bbl model!
cheers
neil
PostPosted: Mon Oct 06, 2008 4:54 pm
I'm also looking at the 2bbl version of the Aussiespeed Hurrican intake manifold. Keep us posted on how your installation goes. One issue that may put me back is that in sizing up the width ( from the intake face that mounts to the head to the outside of the carb pad), is reported to be 460mm. I need to look closer but on this 83 Dodge truck that space is already occupied by the power brake booster / master cylinder. I believe I will be looking into what kind of a job it is to reposition the master brake cylinder.
 Post subject: More About Intake .
PostPosted: Tue Oct 07, 2008 12:50 am
HEY ALL
i am stunned at the responce about the intake .
i went out this arvo and got the bung to block off the brake booster vacum point its 3/8 NTP . i got a nice blue alloy one ..
the guy who i get my carb stuff from was very impressed .,
i have posted some pics on photobucket , with a afb off a 343ci amc on it just to see clearances .
heres the link . http://s256.photobucket.com/albums/hh190/TOOL318/
the black sheep
i like it lumpy
 Post subject: more
PostPosted: Tue Oct 07, 2008 1:09 am
hey back
heres a little more about my set up the car is a 69 valint sedan . 3.23-1 diff open center , 7" wide street tyres pipes up the best ive got is a 17.0 .
the motor is made up from a 60" oversized bottom end,mild head port job and a matched pinned intake to stop miss alingmet of the intake manifold and dubble springs ( 340 v8 stuff 901x )
the bottom end is blanced with a crank bolt and new rod bolts ,the oiling system is cleaned up with the stock pump lifted to 50-55 psi @ 2000rpm hot ,a basic baffed sump .
the sump was finned with 1/8x 1/2 wide flat bar . helps with the heat a little . i also did the timming cover to finnsh it off a little . i am now doing a trans pan and rocker cover just for the fun of it .
sarps come from a 6al and recurved dizzy to make the staic timming 15`btdc . and a stock heavy spirn shortened a little and a msd's silver spring .
the eixt side is a 2 1/2 hi flow exhaust . with 1 muffler and 12ft long hot dog oh and a set of ealy style pacemaker headders i think there 1 5/8 pri to 2 1/4 colectors . a 500edelbrock tops it off and the extreme k and n keeps the crap out ..
and the auto scored a 2000 rpm convetor and a lite shift kit .
so thats it .. for the ..
black sheep ...
i like it lumpy
PostPosted: Thu Oct 09, 2008 6:06 am
i like it lumpy
PostPosted: Thu Oct 09, 2008 7:54 am
Looks nice black sheep...did you make any provisions for some support?
I bought one as well (although there prices went way down after the fact....DOH!)
I was worried about cracking without support & was wondering if you did anything.
PostPosted: Thu Oct 09, 2008 9:36 am
That is a great looking intake. Need to get me some-a that!
PostPosted: Thu Oct 09, 2008 9:59 am
Poser
Stonethk, did you order through Aussie Speed or PP&R? Pentastar Parts still lists the Hurricane @ $465 Aussie. I know Ray was selling on E-bay, is that the price decrease you were talking about?
PostPosted: Thu Oct 09, 2008 11:01 am
OK, so who's going to dyno test this manifold against the Offy and Clifford?
PostPosted: Thu Oct 09, 2008 11:13 am
I would like to do some track testing... swap the Hyper-Pak for the Auzzy manifold to see if there is any difference.
PostPosted: Thu Oct 09, 2008 12:05 pm
Poser
Doc, if Stonethk won't let you borrow his, I would be glad to loan you mine for a while! My build is a long way away and I would love to see what this thing will do! Let me know!
Users browsing this forum: Ahrefs [Bot] and 11 guests
