| Basic wheel/tire upgrade? https://slantsix.org/forum/viewtopic.php?t=31553 |
Page 1 of 3 |
| Author: | Diggity [ Tue Oct 07, 2008 6:01 pm ] |
| Post subject: | Basic wheel/tire upgrade? |
I got a 68 Dart /6. It has the 5x4 13" rims and drum brakes on all 4 wheels. 1. Does anyone make a 13" tire that has the aspect ratio of the original bias ply tire? The tires I have now are like boat trailer tires and they have a pretty short life span. 2. Does anyone make a 14" or 15" rim with the 5x4 bolt pattern? 3. If the above options are not available, is there a list of aftermarket or oem parts to upgrade to the 5x4.5 bolt pattern? If I do this should I switch the front drums for disk brakes? I have always heard the first step to better handling is putting more (high quality) rubber on the road. My goal is to do the wheels/tires/brakes then figure out the sway bars and shocks. I live in the DC area so I have to deal with ALL types of roads. Thanks in advance |
| Author: | rlklaus [ Tue Oct 07, 2008 6:30 pm ] |
If your willing to go aluminum American makes a great looking 14 inch wheel under the Outlaw name. Super wheel for a late 60s look. If I remember correct it's in a 14X6 or maybe 7 wide. Just double checked it's a 14X7, with 0 offset. Part # 624769 is the 5 on 4 inch bolt pattern. |
| Author: | THOR [ Tue Oct 07, 2008 6:52 pm ] |
| Post subject: | Re: Basic wheel/tire upgrade? |
Quote: 2. Does anyone make a 14" or 15" rim with the 5x4 bolt pattern?
Yes... Chrysler did back in the day... 14" steelies became standard equipment in '69/'70 if I remember correctly. At least on the A-bodies.Thanks in advance For aftermarket options, American Racing seems to have the most selection, I haven't seen alot of support lately (the last few years) for SBP mopar... at least where I live, and there are tons of A-body drivers in the Salem/Portland area. Most of them just stick with the factory steel 14"s. ~THOR~ |
| Author: | emsvitil [ Tue Oct 07, 2008 6:58 pm ] |
The correct tire (diameter wise) is a 185 /80 13. But it's a bit wider than stock. The easiest solution is later model steelies or rally wheels with the SBP (small bolt pattern) The steelies are either 14 x 4.5 or 14 x 5.5 The rally is usually 14x6 and I think 14x7 is available. For the 14 x 4.5 you need a 185 / 75 14 tire the 14 x5.5 and 14 x 6 take a 195/70 or 205/70 14 to get the correct diameter. The 14x7 would be a 225/60 or 235/60, but I'm not sure about tire clearance I'm using the 14 x 5.5 with 195/70 14s |
| Author: | vynn3 [ Wed Oct 08, 2008 5:50 am ] |
Rallye wheels in all sizes for the 4" bolt pattern: http://tinyurl.com/3uzpz7 |
| Author: | smith001 [ Wed Oct 08, 2008 6:57 am ] |
I have a 66 valiant that I just put on American Racing Outlaw II wheels and P215/60R14 tires. These were the only wheel I could find in the 5 x 4 bolt hole pattern. They look great and the fit is tight but they work fine. The wheels came from Summit. |
| Author: | 64'4$peed [ Wed Oct 08, 2008 3:25 pm ] |
I've got 215/70R14's in the rear and 205/70R14's in front on my 64 they clear just fine |
| Author: | dookdart [ Thu Oct 09, 2008 6:43 pm ] |
Ive got 5 SBP ralleys. I think they are 14x5.5. Even the later LBP ralleys are 14x5.5. I've also got a full set of 14 steelies, not sure of the width as tires are still on them. I also have a set of alum slots (14x6) is SBP. I'm switching the 69 dart to LBP, the 66 Valiant will most likely stay SBP. I'm not sure if the ralleys or slots will go on the 66. Undecided on that one. |
| Author: | dusterguy225 [ Thu Oct 09, 2008 7:12 pm ] |
I have 14x6 SBP Cragar SS rims on mine. I don't think they even make SBP wheels any more do they? |
| Author: | dookdart [ Fri Oct 10, 2008 5:48 pm ] |
I have a brand new set of cragar ss that I'd like to sell. SBP 14x6 with stock offset, 14x7 with a reverse offset |
| Author: | dusterguy225 [ Sat Oct 11, 2008 2:50 pm ] |
Quote: I have a brand new set of cragar ss that I'd like to sell. SBP 14x6 with stock offset, 14x7 with a reverse offset
Man, I wish I could afford new ones! I got mine with the car, so they were basically free. But, they are starting to show their age.
| Author: | robertob [ Tue Oct 14, 2008 7:06 pm ] |
I have the budget 14-inch setup, 195/70s on the 4.5-inch steel rims. It's narrower than optimum but seems to fit OK. I did want to switch to 14 eventually, but I could not find ANY tire stores that had or could order the 13-inch tires these cars used. We bought a set about 7 years ago from Costco, but they don't have them any more. |
| Author: | wjajr [ Wed Oct 15, 2008 4:20 am ] |
Try Tire rack at: http://www.tirerack.com/tires/SearchTires.jsp |
| Author: | Charrlie_S [ Wed Oct 15, 2008 6:05 am ] |
Quote: I got a 68 Dart /6.
If you are planning to upgrade the brakes, the best thing to do, would be:3. If the above options are not available, is there a list of aftermarket or oem parts to upgrade to the 5x4.5 bolt pattern? If I do this should I switch the front drums for disk brakes? I have always heard the first step to better handling is putting more (high quality) rubber on the road. My goal is to do the wheels/tires/brakes then figure out the sway bars and shocks. I live in the DC area so I have to deal with ALL types of roads. Thanks in advance Brakes first, either 10 inch drums, or better yet, front disc, and 10 rear drum. This will give you the 4 1/2 inch bolt pattern. Then do wheels and tires. There are many wheel/tire combos available for the 4 1/2 pattern in 15 inch or larger. I would not go with 14 inch wheels, as the selection of 14 inch tires is getting smaller. Do a search on this site. There has been a lot of discussion on brakes/wheels/tires. Many options, just depends on your goals, and budget. |
| Author: | Diggity [ Wed Oct 22, 2008 6:58 pm ] |
| Post subject: | Good advice |
Thanks for the good links to wheels and tires. Looks like I'll be keeping the 9" drums as the backs are new and I'm doing the fronts now. Money wise I'm thinking about 700 bucks to change out the wheels and tires to wider 14" rims. I would have to do this anyway if I changed brakes and spindles. What would be cool is if I could find some original size bias ply tires!... |
| Page 1 of 3 | All times are UTC-07:00 |
