It is currently Sat Jun 13, 2026 8:28 pm
PostPosted: Wed Oct 08, 2008 4:38 pm
Is there an easy way to determine if the head or block has previously been milled. I may have the head modified this winter with a bit of porting & decking, and over sized valves.
PostPosted: Wed Oct 08, 2008 5:03 pm
The block is easy - by the alternator, on the block, there's a pad of material sticking out that has block size and various symbols to indicate journal under size, etc. If those stamps are gone, block has been milled before.
PostPosted: Thu Oct 09, 2008 6:24 am
With a head you pretty much have to CC the chambers to get a starting point. Casting/machining of factory heads was not that exact to have a decent measurment to go by. :shock:
PostPosted: Thu Oct 09, 2008 8:04 am
While not totally reliable, I have found all the stock heads, I have, will measure 3.595 to 3.606 inches, from the head/deck surface to the valve cover mounting surface. This will at least tell you if the head has been cut a lot or not. The best way is to cc the combustion chamber, but this can give you a ball park indication.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
