It is currently Tue Nov 17, 2026 9:13 am
 Post subject: thrush?
PostPosted: Sat Oct 11, 2008 7:47 am
what kind of muffler would make a slant six sound "mean"? I was thinking of a thrush of some kind and I found a thrush glasspack with single inlet and dual outlet but I don't know what it'd sound like...???
PostPosted: Sat Oct 11, 2008 11:30 am
i had california turbo`s on my street car, they sound good to me, just don`t go over board on the pipe dia.
PostPosted: Sat Oct 11, 2008 11:36 am
I am running the $29.00 Thrush version of the Flow Master 40. Very mellow most of the time until you step on it. Nice growl..... :D
PostPosted: Sat Oct 11, 2008 1:42 pm
I'm not happy with the thrush turbo I have now. I can barely hear it at cruise in the car. It is only loud behind the car. I really liked my cherry bomb turbo muffler. It rumbled at idle, growled at cruise and snarled loud at WOT.
PostPosted: Sat Oct 11, 2008 7:00 pm
My Dart used to have a Thrush Magnum Glasspack with a side exit exhaust. That one was loud. It's definitely not the same tone as you'd get with a V8 with glasspacks, however.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Oct 12, 2008 8:37 am
my main issue is money right now so I can't go with actual dual exhaust so I was gonna try the thrush with dual outlets to maybe see if it'd make it sound a little more "dually"... haha
PostPosted: Sun Oct 12, 2008 12:18 pm
Go with the Thrush welded muffler (Flow Master 40), it is certainly cheap enough at $29.00 and growls very nicely.....
Not to be confused with the Thrush turbo muffler.
Last edited by Aggressive Ted on Sun Oct 12, 2008 7:52 pm, edited 1 time in total.
PostPosted: Sun Oct 12, 2008 7:50 pm
Car Model: 63 Dart 81 D150
I have a 2"ish manifold pipe running in to a single in dual out generic flowmaster, with dual flexi tailpipes. It sounds good even with a dead smooth idle. Around 2000 to 2500 rpm or so, under hard acceleration it is a bit loud, but otherwise it sounds nice.
I highly recommend a 2" manifold pipe as it is hard to get a good sound from a stock 1.75 pipe, the smaller the pipe, the more hondaish it sounds.
See this thread too:
http://slantsix.org/forum/viewtopic.php ... highlight=
TopHat
PostPosted: Mon Oct 13, 2008 2:43 pm
mine sounds great with out one!! :D
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Sun Oct 19, 2008 12:11 pm
what do ya spose the thrush glasspack with dual outlets, with a pipe coming out each side in front of the back wheels would sound like?
PostPosted: Sun Oct 19, 2008 12:42 pm
If you are short on money get Teds style of muffler and a 2 1/4 pipe from manifold to rear bumper. Add tip of choice.
You will keep it quiet inside....get best performance ....for the smallest buck.....with the coolest tunes.
A single to dual short pipes will cost more and give less.
Side exhausts usually get rubbed off around here.......
