| thrush? https://slantsix.org/forum/viewtopic.php?t=31627 |
| Author: | plymouthhillsidehemi225 [ Sat Oct 11, 2008 7:47 am ] |
| Post subject: | thrush? |
what kind of muffler would make a slant six sound "mean"? I was thinking of a thrush of some kind and I found a thrush glasspack with single inlet and dual outlet but I don't know what it'd sound like...??? |
| Author: | terrylittlejohn [ Sat Oct 11, 2008 11:30 am ] |
i had california turbo`s on my street car, they sound good to me, just don`t go over board on the pipe dia. |
| Author: | Aggressive Ted [ Sat Oct 11, 2008 11:36 am ] |
I am running the $29.00 Thrush version of the Flow Master 40. Very mellow most of the time until you step on it. Nice growl..... |
| Author: | 70valiant [ Sat Oct 11, 2008 1:42 pm ] |
I'm not happy with the thrush turbo I have now. I can barely hear it at cruise in the car. It is only loud behind the car. I really liked my cherry bomb turbo muffler. It rumbled at idle, growled at cruise and snarled loud at WOT. |
| Author: | Matt Cramer [ Sat Oct 11, 2008 7:00 pm ] |
My Dart used to have a Thrush Magnum Glasspack with a side exit exhaust. That one was loud. It's definitely not the same tone as you'd get with a V8 with glasspacks, however. |
| Author: | plymouthhillsidehemi225 [ Sun Oct 12, 2008 8:37 am ] |
my main issue is money right now so I can't go with actual dual exhaust so I was gonna try the thrush with dual outlets to maybe see if it'd make it sound a little more "dually"... haha |
| Author: | Aggressive Ted [ Sun Oct 12, 2008 12:18 pm ] |
Go with the Thrush welded muffler (Flow Master 40), it is certainly cheap enough at $29.00 and growls very nicely..... Not to be confused with the Thrush turbo muffler. |
| Author: | tophat [ Sun Oct 12, 2008 7:50 pm ] |
I have a 2"ish manifold pipe running in to a single in dual out generic flowmaster, with dual flexi tailpipes. It sounds good even with a dead smooth idle. Around 2000 to 2500 rpm or so, under hard acceleration it is a bit loud, but otherwise it sounds nice. I highly recommend a 2" manifold pipe as it is hard to get a good sound from a stock 1.75 pipe, the smaller the pipe, the more hondaish it sounds. See this thread too: http://slantsix.org/forum/viewtopic.php ... highlight= TopHat |
| Author: | theslantingsix [ Mon Oct 13, 2008 2:43 pm ] |
mine sounds great with out one!! |
| Author: | plymouthhillsidehemi225 [ Sun Oct 19, 2008 12:11 pm ] |
what do ya spose the thrush glasspack with dual outlets, with a pipe coming out each side in front of the back wheels would sound like? |
| Author: | sandy in BC [ Sun Oct 19, 2008 12:42 pm ] |
If you are short on money get Teds style of muffler and a 2 1/4 pipe from manifold to rear bumper. Add tip of choice. You will keep it quiet inside....get best performance ....for the smallest buck.....with the coolest tunes. A single to dual short pipes will cost more and give less. Side exhausts usually get rubbed off around here....... |
