It is currently Sat Aug 15, 2026 9:21 am
 Post subject: New parts in MCG !?!!
PostPosted: Sun Jan 27, 2002 5:10 am
Hey...how about this?
Marcg issue...MCG,pg. 10...Bulletproof front trans bearing retainer, machined from steel billet, not cast iron. (For those of you that have a tendency to abuse & break your manual trans parts)
Pg. 11...Dropped spindles for the 4.5" pattern...get the nose of your car down without "adjusting" torsion bar tension.
Pg. 12....a steering shaft rebuild kit....to relieve some of the play, and help keep you from looking like a DUI candidate.
Pg. 13...New trans mount for '66-'71 A-body....in either rubber or poly. (No more knockin' on the floor at launch!)
Picked up the magazine Friday afternoon, thought the rest of you might be interested.
Roger
GTS225@aol.com
PostPosted: Sun Jan 27, 2002 10:38 am
I really like the new poly trans mount for the A-Body, need to get me one of those to try.
MCG has been growing over the years, they have been nice to the SL6 Racers by covering the results of all of our SSRN Points Series races.
Is it me or does it seem that MCG is getting more "mainstream" as time goes on? Over the years, I can remember reading some pretty crazy stuff in MCG but hey, it's a free country, print what you want to. (or dare to!)
One "bummer" for me is that MCG is tough to find on a newstand out here in California.
: March issue...MCG,pg. 10...Bulletproof front
: trans bearing retainer, machined from steel
: billet, not cast iron. (For those of you
: that have a tendency to abuse & break
: your manual trans parts)
: Pg. 11...Dropped spindles for the 4.5"
: pattern...get the nose of your car down
: without "adjusting" torsion bar
: tension.
: Pg. 12....a steering shaft rebuild kit....to
: relieve some of the play, and help keep you
: from looking like a DUI candidate.
: Pg. 13...New trans mount for '66-'71
: A-body....in either rubber or poly. (No more
: knockin' on the floor at launch!)
: Picked up the magazine Friday afternoon,
: thought the rest of you might be interested.
: Roger
