| Clearance between rim spoke and caliper https://slantsix.org/forum/viewtopic.php?t=31818 |
| Author: | stonethk [ Tue Oct 21, 2008 5:43 pm ] |
| Post subject: | Clearance between rim spoke and caliper |
I'm almost done with my disc brake conversion and need some advice. So the rim spoke is just rubbing the caliper (cragars What is the minimum space I should have between the caliper and spoke? Is 1/8" to little? |
| Author: | sandy in BC [ Tue Oct 21, 2008 6:47 pm ] |
I had to grind the calipers on the rear of the Valaint to clear the rims....its not unusual. As long as they clear it doesnt matter how much. |
| Author: | stonethk [ Wed Oct 22, 2008 7:08 am ] |
Thanks, that is what I needed to know. |
| Author: | sixinthehead [ Thu Oct 23, 2008 10:33 am ] |
Be sure to measure with a new outboard pad. As it wears, you'll get even more clearance. |
