empty rear resevoir
https://slantsix.org/forum/viewtopic.php?t=31944
Page 1 of 1
Author:  Bren67Cuda904 [ Tue Oct 28, 2008 5:29 pm ]
Post subject:  empty rear resevoir
Its been a while since I've been on here. It seems as if my car had to remind me to check in.
Tonight I hopped in the car and found the pedal a lot soft. I popped the hood and found the rear resevoir empty. I filled it and snapped the lid back on and took the baby sister home. The trip is about 7miles round trip and by the time I got back home the pedel felt normal again. This car has the MP disk brake conversion and is manual assist. I looked all around the car for leaks and found none. Checked hoses, steel line and even the backing plates for moister. I havn't pulled the drums to look at the wheel cylinders them selves, as I believe the rear resevoir feeds the front calipars. Any ideas as to where the fuild has gone to?
http://tinyurl.com/yoasgs
http://tinyurl.com/ytpvuy
Author:  emsvitil [ Tue Oct 28, 2008 5:34 pm ]
Your carpet.............
Author:  dakight [ Tue Oct 28, 2008 6:06 pm ]
As the brakes wear it's normal for the reservoir level to drop; the rear chamber feeds the front brakes. Also, fluid can be pumped from the rear reservior into the front if the piston cups are worn.
Author:  andyf [ Tue Oct 28, 2008 7:34 pm ]
My guess is that aliens probed your rear reservoir
Author:  Bren67Cuda904 [ Mon Nov 03, 2008 7:49 am ]
Found fluid on inside of firewall.
Where are we getting the good master cylinders now?
Author:  radarsonwheels [ Mon Nov 03, 2008 10:09 am ]
Post subject:  I got the two bolt one
It is aluminum with plastic res. and you need a four to two bolt adaptor. I got mine off ebay. I just put it on and bled an entirely new system with no problems and good pedal feel. It was also WAY lighter than the iron doorstop I took off. It also came with the rubber retainer for the pushrod.
I think a few different people are selling them.
Good luck and be safe
radar
Author:  Bren67Cuda904 [ Mon Nov 03, 2008 6:55 pm ]
I'd like to stay with the iron 4 bolt one. Do we have a source for these, that are good?
Author:  Charrlie_S [ Tue Nov 04, 2008 4:59 am ]
Bendix catalog shows 11323 as a NEW master for 10 inch drum brake car.
It is 1 inch bore.
Shows R11487 as a REMAN for a disc brake car (1 1/8 bore). Does not show a NEW disc brake MC.
Author:  Bren67Cuda904 [ Wed Nov 05, 2008 9:05 am ]
The 11323 is wrong. It has a semetrical resivore patern. I need a large rear resevore. I found out that the master I have is suppost to be a 1-1/8 bore. The pedal feels "OK" but is a little stiff. Anyone see a problem going to a 1" or even a 15/16" bore?
The reman part # doesn't seem to cross at Napa
Author:  Charrlie_S [ Wed Nov 05, 2008 11:52 am ]
That is correct, that is for a 10 drum brake car
R11487 is for the disc brake, and is a 1 1/8 bore. Bendix does not list a NEW MC for that application. A number for new, would be 11487, delete the "R".
This info is right from the Bendix CD catalog, which does an online automatic update, whenever it is accesed.
A smaller bore master cyl will require less pedel effort, but have more pedal travel.
Author:  Bren67Cuda904 [ Wed Nov 05, 2008 3:13 pm ]
Is there really any danger of using to small of a bore and having the pedel reach the floor before the brakes are applied? (providing system has been beld properly)
