| Which Compression Tester? https://slantsix.org/forum/viewtopic.php?t=32122 |
| Author: | Slanted Opinion [ Fri Nov 07, 2008 8:39 am ] |
| Post subject: | Which Compression Tester? |
I hope this topic is in the correct forum. I need a new compression tester. Old one is shot and never sealed very well. Which one works best with the old-style (spark plug tube) heads? -Mac |
| Author: | Joshie225 [ Fri Nov 07, 2008 8:48 am ] |
I have an inexpensive one with a quick connect hose. I pull the spark plugs and tubes, thread in the hose and connect the gauge. I use the same hose with the check valve removed for holding valves closed while changing valve springs or valve stem seals. |
