It is currently Mon Nov 16, 2026 3:51 pm
PostPosted: Fri Nov 07, 2008 8:39 am
I hope this topic is in the correct forum.
I need a new compression tester. Old one is shot and never sealed very well.
Which one works best with the old-style (spark plug tube) heads?
-Mac
PostPosted: Fri Nov 07, 2008 8:48 am
I have an inexpensive one with a quick connect hose. I pull the spark plugs and tubes, thread in the hose and connect the gauge. I use the same hose with the check valve removed for holding valves closed while changing valve springs or valve stem seals.
