It is currently Sat Nov 21, 2026 3:06 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sat Feb 09, 2002 3:08 pm
I replaced my single pulley alternator w/ a dual pulley alternator (the only alternator they had that would fit my car), and as a result, my belt runs at a very slight slant (what i mean is, it's a little bit further forward than it was before). Will this affect anything, or is this arrangement okay?
Thanks again for your help,
Robert.
countchocula@forpresident.com
PostPosted: Sat Feb 09, 2002 4:24 pm
: I replaced my single pulley alternator w/ a
: dual pulley alternator (the only alternator
: they had that would fit my car), and as a
: result, my belt runs at a very slight slant
: (what i mean is, it's a little bit further
: forward than it was before). Will this
: affect anything, or is this arrangement
: okay?
: Thanks again for your help,
: Robert.
A little misalignment won't hurt for a short time. Long term, you're going to hurt the bearings. Also not doing the belt any favors.
Do you have your single pulley? Option #1 would be to swap the pulleys. Option #2 would be to find the crank and water pump pulleys to match your new alternator. Option #3 would be to shim the old pulleys.
Gilly
tlg225ccr@aol.com
PostPosted: Sat Feb 09, 2002 7:27 pm
I *NEVER* use "remanufactured" parts from the parts store. My experience with them over the years has been so awful, from so many sources, that I find it far cheaper and much more effective in the long run to take the time and effort to obtain a properly-repaired ("rebuilt") item done by a competent independent technician. The factory-reman starters, alternators, carburetors, etc. are usually thrown-together junk made with parts from six or seven different originals and put together with low-quality replaceable/wear parts. I find that "lifetime warranty" just means you get to spend your "lifetime" returning parts under "warranty" and getting hassled by the counterman at the parts store. No thanks!
Sounds like you put the belt on the foreward belt groove. When using a dual-pulley alternator on a car that came with a single-pulley unit, the REAR groove is the correct one.
: is this arrangement okay?
No. You're going to lose your belt in a hurry. If putting the belt on the rear groove doesn't fix it, the alternator wasn't assembled correctly.
Don't count on an exchange replacement being assembled correctly, either.
DS
redbear@vrx.net
PostPosted: Mon Feb 11, 2002 9:01 am
: A little misalignment won't hurt for a short
: time. Long term, you're going to hurt the
: bearings. Also not doing the belt any
: favors.
: Do you have your single pulley? Option #1 would
: be to swap the pulleys. Option #2 would be
: to find the crank and water pump pulleys to
: match your new alternator. Option #3 would
: be to shim the old pulleys.
: Gilly
I have used "option # 1" a few times over the years, with the correct puller, that little pulley comes right off.
I would take a measurment first, remove the pulleys and swap the single groove over to the new unit. ( a good independant parts store with a small shop can do this or a decent auto repair garage)
If both grooves on the double pulley do not line-up correctly, I would say the pulley is not pressed completly onto the shaft. Here again, I would pull it off and do some checking before tring to push it on "deeper".
PostPosted: Mon Feb 11, 2002 1:15 pm
: I have used "option # 1" a few times
: over the years, with the correct puller,
: that little pulley comes right off.
: I would take a measurment first, remove the
: pulleys and swap the single groove over to
: the new unit. ( a good independant parts
: store with a small shop can do this or a
: decent auto repair garage)
: If both grooves on the double pulley do not
: line-up correctly, I would say the pulley is
: not pressed completly onto the shaft. Here
: again, I would pull it off and do some
: checking before tring to push it on
: "deeper".
: DD
I had a 68 Valiant with a slant and it originally came with the single pulley alternator. When I went to the 61 amp alternator all I could find was the double pulley type. I ran the car like this for years with the belt on the back groove of the pulley. This gave the best alignment. I think I changed 1 belt and 1 alternator in 5 years and this was my daily transportation. The 61 amp worked better with A/C and electronic ignition.
mwhiteho@hotmail.com
