It is currently Thu Nov 19, 2026 8:38 pm
 Post subject: 1.6 rockers
PostPosted: Sun Nov 16, 2008 10:48 am
OK here is the low down - I have a bunch of normal rockers -and I think that clifford sorted through theirs to get the ratio
Ideas? :?
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sun Nov 16, 2008 11:20 am
Er-ruhh...I can't tell what you're asking here. :shrug: :?:
PostPosted: Sun Nov 16, 2008 11:41 am
Someone one the board bought the 1.6:1 Clifford rocker arms. They are not Chrysler rocker arms. They are some kind of cast or forged arm with adjusting screws placed at an odd angle that will affect the ratio depending upon the placement of the adjusting screw. My inner engineer cringed when I saw them.
The discussion was in this thread: http://slantsix.org/forum/viewtopic.php?t=30156
The guy that bought a set sent me pictures. They are not what's pictured on Clifford's web site. I'm not having luck finding the pictures though.
PostPosted: Sun Nov 16, 2008 11:43 am
Bugger
Regards,
Fanie Gerber
PostPosted: Sun Nov 16, 2008 11:48 am
What are you trying to accomplish? Lots of valve lift with a short duration?
PostPosted: Sun Nov 16, 2008 11:55 am
Clifford's showing one thing and sending something else? And that something-else is poorly made?
I'm shocked. Shocked, I am! :lol: :twisted: :roll:
PostPosted: Sun Nov 16, 2008 5:08 pm
Mee too.
:shock:
PostPosted: Mon Nov 17, 2008 12:54 pm
I believe that your trying to ask if you have a lot of rockers can you do what clifford did and get a 1.6 ratio?
I'm assuming that the measure through hundereds of rockers and get a set that is close to a 1.6 ratio. Mine I've measured out are pretty close all in all but come in around 1.4X which is a little lower than there suppose to be huh?
What would make more sense to me and something I might try instead of roller rockers is to cut out the bushing in the middle and have an offset one but in to achive whatever I want. Now it may not be possible to move it that much for material vs strength issue or something but I will have to get out the micros over winter break and see what we got.
PostPosted: Mon Nov 17, 2008 1:26 pm
A good understanding only needs halve a word :D
YES my thoughts exactly Rolers are just to expensive!!
Regards,
Fanie Gerber
PostPosted: Mon Nov 17, 2008 6:36 pm
I once modified a stock rocker to a 1.55 ratio. I haven't tried running it yet.
http://slantsix.org/forum/viewtopic.php ... highlight=
Franklin
'61 Valiant
PostPosted: Mon Nov 17, 2008 6:54 pm
I do have this sextet of 1.6-ratio Gotha rockers, which bring a smile to my face because they're such a nice casting. Just for that, I wish they were still available. (Fanie Gerber, please come to the nearest paging telephone? Fanie Gerber to a paging telephone, please...) though I still would want tip-end oiling.
PostPosted: Mon Nov 17, 2008 8:41 pm
Casting-R-US Yes can I help you :lol:
Regards,
Fanie Gerber
PostPosted: Tue Nov 18, 2008 6:29 am
I donno, you tell me: Can you?
