It is currently Thu Jul 16, 2026 10:49 pm
Post new topic  Reply to topic  [ 131 posts ]  Go to page 1 2 3 4 59 Next
 Post subject: Winter 2008 Car Projects
PostPosted: Fri Nov 28, 2008 12:18 pm
Site Admin
Lets start it off with possible 12-14 second cars being built over the winter for the Killer Bee Racing Team:
1- Sergios "secret project"
2- Andrews "junk yard/skull and crossbone excpress" with a really bad boy new motor
3- WB with his 198 project
4- Dana with his new motor
5- The Fox project (Arrow) from Oroville
6- CJ new project
7- Glen moving to 14's with much more power, maybe a altered wheelbase car.
8- PJ with less turns on the throttle stop..She ran low 15's last year but this car will go alot..alot faster
9-Fopar may be Mopar now as has in working on a early lightweith 63'
10- Doug Powers is now retired and will be working on a 13 second 170 powered car...Good..there will finally be someone with another 170...
11- Josh with his RX-203 project..
12- David with new roller rockers...should be 13 second car again..
PostPosted: Fri Nov 28, 2008 12:55 pm
I'll go first...
The car will be powered by a +.040" 198 which makes 203ci so the RX-273 will change to RX-203. The engine going to be about 10.25:1, decent cam, Clifford intake, headers, etc. It's going to have a full exhaust system and working lights so I may even drive it around a bit and run it at the late night drags in Portland. I'll be happy if it's under 2700 lbs with driver, but it may be a little over that. If it doesn't get done in time I still have the Valiant for the first race or two.
PostPosted: Sat Nov 29, 2008 9:20 am
OK.....my car is at www.munkracefab.com now - It will be getting subframe connectors,cross bar...few other things.
The engine i am building is going to run on 6 cylinders this year....and may even break my 16.75 times.LOL
I hope to get the engine bits all here soon.....just got a box from Doug.(thanks Doug!!)now just waiting on more stuff before we take it all to the machine shop.Will be spending more time w/ the crank and die grinder next weekend I hope.....can we say knife edge?
Andrew/Kidd
Wife's: 64 Valiant
My: 70 Road Runner, 67 Barracuda, AND the 62 Valiant drag car!!
PostPosted: Sat Nov 29, 2008 10:06 am
Site Admin
Killer Bee's aren't the only ones building stuff! Sing out if you have something cooking!
6- CJ new project
PostPosted: Sat Nov 29, 2008 10:15 am
I am installing a fuel cell and lines in my 66 Valiant. Also will be totally redoing the ignition and fuel system wiring. Hope to get rid of my annoyning misfire, and get it into the 12's. Will also need new slicks.
Will also be working on my 65 Valiant, 170 turbo car. Maybe have it running, again, in 2009.
PostPosted: Sat Nov 29, 2008 11:13 am
6 Pack Dart
Well it is a Mopar, May not look real nice but hope my :?: project will make it run good. :twisted:
 Post subject: Winter project
PostPosted: Sat Nov 29, 2008 10:58 pm
Nice projects folks and the RX will be very nice when done, nice cage work Josh! My project's progress is hinging on the selling of my '71 GTX, but I will be working on the slant racer this winter when I can. It's a '65 Valiant, 2 dr sedan, narrowed 8 3/4, coil-overs w/ladder bar rear suspension, disc brakes all around, fiberglass hood and scoop, lexan to replace the safety glass and some serious sawzall work. The engine's going to be a normally aspirated 170 w/198 crank and should finish in the 214 cid range (nothing trick and pretty straight-forward), coupled to an 833 4 spd. Should be fun, especially with the clutch-assisted 4 gear! I'm REALLY looking forward to getting this slant racer going as I know it'll be loads of fun, and that is the name of this game...FUN! I can say for sure, it will NOT be running this year but my wife's fresh '74 Dart Sport will be. I hope to see y'all next season, in the meanwhile...wrench hard and keep warm!...wb
PostPosted: Sun Nov 30, 2008 12:53 pm
Site Admin
6- Andrew's new Kidd car.
I replaced my name on the list with Andrew. I will not be building a new car this winter. I may make some tweaks to the Hooptie, and hope to make some progress on Linda's car, but none of that will be ready for next season.
CJ
PostPosted: Sun Nov 30, 2008 3:58 pm
My Daytona is supposed to be gotting into my buddy's shop in 2 weeks to start the firewall/cage modifications to make a Slant fit. Right now it seems like springtime is a long way away and we have plenty of time, but I have been fooled before. :cry:
PostPosted: Sun Nov 30, 2008 4:20 pm
Site Admin
13- Slantzilla-The Killer Bee Daytona project
PostPosted: Sun Nov 30, 2008 4:28 pm
CJ- makes me look like I am building 2 cars!!!! I am just building mine, and working on the Wife's car!!
Andrew
Wife's: 64 Valiant
PostPosted: Sun Nov 30, 2008 5:36 pm
New turbo engine for the Dart.
PostPosted: Sun Nov 30, 2008 5:53 pm
Site Admin
6- Shaker223 - Turbo car
There we go. All better!
PostPosted: Mon Dec 01, 2008 1:10 pm
I have several projects going, as always, but on my same 3 cars.
Project V will be re-released as version 2.0 (hell or high water). 2600-2650 w/driver and new motor, rear, body, etc... 13s for sure. 12s??
'64 Dart will get some engine mods, just finished front susp and brake upgrade and tubular sway bar. Possible new engine if time?
'68 Dart has turbo exh manifold under construction, frame connectors, and cam swap is planned. 15s on motor (again, slower since 2001), then turbo will go on for 2010...
PostPosted: Mon Dec 01, 2008 2:19 pm
Site Admin
14- Lou- Project V Release 2.0
