It is currently Sat May 09, 2026 10:03 pm
PostPosted: Mon Dec 01, 2008 10:03 am
ANYONE OUT THERE HAVE A SOURCE FOR A SLANT 6 TO BORG WARNER T-5 TRANSMISSION ADAPTOR . OR ANY INFO REGARDING SAME ---I HAVE SEVERAL TRANSMISSIONS FROM S-10 CHEVYS AND THINK THEY WOULD BE A GOOD MATCH FOR MY STREET ROD PROJECT ----PLEASE CRITIQUE IF YOU THINK I AM GOING IN THE WRONG DIRECTION ---THANKS
PostPosted: Mon Dec 01, 2008 11:36 am
Site Admin
Hi Greg,
Check your PM's!
CJ
PostPosted: Mon Dec 01, 2008 12:52 pm
I did a group machining buy 3 yrs ago to put an adapter plate on a slant 6 OD bellhousing. 17 BH's were modified with the plate to mount a T5. I would post on "Parts Wanted" that you are looking for one. $300 would be a decent price for the complete bell. $350 was probably invested on each one.
I have a T5 in my '64 Dart and about 5-7 other guys have done this so far.
 Post subject: Good call...
PostPosted: Mon Dec 01, 2008 7:28 pm
No that's a good call, I have a truck bell I need to figure out whether I am going A-833OD or T-5 on... after comparing all the T-5 data it looks like the mustang 5.0 has a good gear spread with OD to run 3.91/4.11 gearing without going to too granny on the 1st gear....
-D.idiot
 Post subject: t-5
PostPosted: Tue Dec 02, 2008 5:12 am
the only reason i am thinking t-5 is i have 2 ----one from a mid 80's v6 s-10 and one from a 4 cyl ---the v6 only had 1500 miles on it taken from a wreck ---dont know the ratios yet but i can research them on a web site called www.inliners.org ---you need the id tag from the trans and it gives all the ratios ---------the t-5 has the same bolt pattern as any chevy 3 or 4 speed so there should be a adaptor out there someware for a chevy 3 or 4 speed ---the onlt issue i see is clutch because the t-5 has a different spline count ---probably need to have a clutch custom made . clutch linkage will not be a problem because i will use a hyd slave cyl setup or possibly a hyd throw out bearing if enough room in bellhousing -----the trans should be stout enough for the slant 6 torque output --- i dont expect to pound on it regurarly ---just have to watch the hole shots and power shifting ----the s-10 trans also has a more desireable shifter location for my application as it is directly behind the gear box as opposed to the more common rear tailshaft location . ----good luck on your project and thanks -------greg
PostPosted: Thu Dec 11, 2008 11:22 am
the shifter pad location on the s10 5 speeds is gonna be too far forward if this is going in an A body mopar. S10 tranny's do work good in street/hot rods though. the input shaft on the mustang tranny is also longer making it easier to reach the pilot bearing.
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Mon Jan 12, 2009 7:47 pm
check the trans mounting pad. i know the camaros and firebirds were machined at a 15* angle to help with shifter angle. i don't know if they did it with the trucks as well.
zedpapa
soon to have 5 gears!!!
