It is currently Sun Nov 22, 2026 3:29 am
 Post subject: Timing Set
PostPosted: Tue Dec 02, 2008 6:21 pm
Is there a recommended timing set supplier, with hardened steel gears, double roller, multiply keyways in lower gear?
I looked at:
1) hughesengines.com, does not have multiple keyways
2)Cox Brothers, posted in this forum under parts, phone listed is disconnected
3) Rollmaster, Red Series, fits the requirements, but 110.00 US and shipping from Australia does not.
who else is worth looking at
thanks
PostPosted: Tue Dec 02, 2008 6:28 pm
You've found the good ones. Most folks that bother to degree the cam drill the indexing hole in the cam sprocket to accept an offset bushing.
I'd ask Hughes why he doesn't supply a multiple keyway crank sprocket with his timing set since he could use the same one as in his 6427 or 6430 timing sets for B/RB engines.
PostPosted: Tue Dec 02, 2008 7:25 pm
Spoke with Kevin at hugesengines about an alternative lower gear that is keyed, He said that he looked at a keyed v-8 lower gear and it had a larger ID, I'll call again tomorrow and mention the set up that you mentioned.
PostPosted: Tue Dec 02, 2008 7:59 pm
The slant uses the same timing chain and crank sprocket as B/RB engines. You can take that to the bank.
PostPosted: Wed Dec 03, 2008 4:56 am
My opinion is the multi-keyed crank sprocket is a pain in the keester. I always use a offset cam bushing (chevy ones work fine), even if the crank gear is keyed.
Here is the JP chain less then $100 shipped.
E-Bay number 190257960633
PostPosted: Wed Dec 03, 2008 12:09 pm
Dadtruck,
If you want a new in box rollmaster set from here in NC, PM me. I guarantee to beat the list price, I am not gonna use it. Never out of box.
rock
'64d100
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
