It is currently Wed May 20, 2026 7:29 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Super Six Problems..
PostPosted: Mon Feb 18, 2002 7:04 pm
I recently put a Super Six intake on 75 Duster with a /6. After having it put on, I feel no real power change. Also, when I give it more than approx 1 in. of the gas pedal down, it dies on me. I have a Carter 2bbl on it btw. What could be cuasing this stall? What could I do to make it perform as it should.
-Nick
NickiDee119@aol.com
 Post subject: Re: Super Six Problems..
PostPosted: Tue Feb 19, 2002 1:36 pm
: I recently put a Super Six intake on 75 Duster
: with a /6. After having it put on, I feel no
: real power change. Also, when I give it more
: than approx 1 in. of the gas pedal down, it
: dies on me. I have a Carter 2bbl on it btw.
: What could be cuasing this stall? What could
: I do to make it perform as it should.
: -Nick
First, I would check for vacuum leaks either where the intake manifold meets the head or where the carburetor meets the intake manifold.
Patrick Devlin
pwd22@drexel.edu
PostPosted: Tue Feb 19, 2002 3:57 pm
It's possible that you may be able to get rid of the stalling by adjusting the accelerator pump linkage. In my case I spent so much time adjusting the linkage that I replaced the bend to adjust linkage with a modified turnbuckle. Takes a little effort to change the ends so it'll fit but I've found it makes tuning a lot easier!
Matt
: -Nick
PostPosted: Thu Feb 21, 2002 9:06 am
: -Nick
Did it have a hesitation before you put it on? If so check the distributor and make sure that the mechanical advance is working. If the timing doesn't advance when the rpm's come up then it will hesitate and backfire through the intake or stall. If you didn't have the problem until you installed the new intake and carb then make sure the accelorator pump is working and adjusted properly. If it is then make sure the carb doesn't have some plugged passages inside.
joel_harris@fmo.com
