It is currently Mon May 18, 2026 7:40 pm
 Post subject: Fixed Kick Down?
PostPosted: Thu Dec 11, 2008 11:41 pm
I have a 2bbl intake and non cracked exhaust manifold in the shed.
I rebuilt a BBD. Can I run this without the kick down linkage? Set the lever on the tranny to a "happy medium?"
PostPosted: Thu Dec 11, 2008 11:56 pm
Not if you ever want the transmission to shift when it's supposed to, last like it's supposed to or perform well.
PostPosted: Fri Dec 12, 2008 5:47 am
I pretty much agree with Josh. But you can do it for a while with no ill effects as a stopgap. Just make sure it's high enough to give you somewhat of a crisp shift and not shift too early (20 MPH for 1-2, 30 MPH for 2-3 at least).
LLou
PostPosted: Fri Dec 12, 2008 7:08 am
Yeah, the others are right. This can get you by for a short time while you collect pieces for a kickdown, but it is not a long-term fix. See this thread for kickdown options.
